POV-Ray : Newsgroups : povray.general : Server failure Server Time
7 Apr 2026 21:07:10 EDT (-0400)
  Server failure (Message 1 to 10 of 88)
Subject: Server failure
Date: 14 Mar 2021 22:10:49
Message: <604ec229$1@news.povray.org>
Folks,
The povray.org server had a catastrophic hardware failure on March 9 and
it was decided that the best course was to replace it completely.
In doing so I chose to do a full, fresh install of the OS rather than
attempt to re-install the old one, and only import the data from our
backup that we needed to get the various services back up.
As the failed system was 15 years old and had been through multiple
upgrades and patches this meant quite a lot of work to replicate configs
with the latest software versions and required re-compiling all the
custom tools (e.g. the NNTP to Web gateway) we have build over the
years. Hence it's taken longer than I would have liked to get it working
again, but IMO it's worth the effort.
The NNTP server is the first to be brought back online and at the time I
post this is the only service running and publicly accessible. Posts
made here will eventually migrate to the web view once that's sorted and
back up; in the meantime only NNTP users will see this message.
Before anyone asks - yes I did consider pointing the web sites
(povray.org, irtc.org etc) to another server and in fact I did for a
short time, with a simple placeholder page at the root of each site. I
quickly noticed from the logs, though, that almost instantly I was
getting lots of web crawler traffic (google, bing, etc) and that the
server was returning "404 not found" to all accesses excepting the root
placeholder page that I'd put in.
That wasn't desirable as it tells the crawlers that the pages that they
are trying to refresh are no longer there, and they also see the simple
root page as no longer having any links. I considered changing the
config so it returned the placeholder page for all URL's, but that had
the downside that it would replace any cached content with the
placeholder, screwing up future searches.
I decided that rather than muck around with other solutions (e.g. return
a temporary failure for all URL's) I'd be better off spending my time
getting the new server configured, so I pointed the sites back how they
were. I didn't know at that point that the server was toast and thought
it might be only a day or two and haven't had time since then to
re-visit it.
Finally, I'd like at this point to give a MASSIVE shout-out to Andrew at
Netplex Internet in CT, who not only provided us with the replacement
server (a HP DL360 G5 that they were no longer using) but also stayed up
until 5am on Saturday getting it set up and configured to the point
where I could remotely log in and start the setup.
-- Chris
Subject: Re: Server failure
Date: 14 Mar 2021 22:13:51
Message: <604ec2df$1@news.povray.org>
Forgot to mention ... at this point it appears we've only lost about one
day of data (primarily posts to the newsgroups) as I recovered from a
backup taken the previous night.
-- Chris
Date: 15 Mar 2021 05:03:21
Message: <0552f79d71dfa9154a9ae48416e0310f4ed8a3cb.camel@hotmail.fr>
On lun., 2021-03-15 at 13:10 +1100, Chris Cason wrote:
> Folks,
> and
> than
> configs
> working
> time I
> and
> I
> root
> they
> simple
> had
> return
> time
> they
> thought
> re-visit it.
> at
> replacement
> up
> -- Chris
Thanks a lot for your dedication.
Many people are following and encouraging your efforts from the two POV
related Facebook groups:
https://www.facebook.com/groups/739767156410999
https://www.facebook.com/groups/fansofpovray
Date: 15 Mar 2021 08:56:18
Message: <604f5972$1@news.povray.org>
On 3/14/21 10:10 PM, Chris Cason wrote:
> Folks,
> -- Chris
Thank you Chris!
Thank you Andrew!
Bill P.
Date: 15 Mar 2021 10:02:08
Message: <604f68e0@news.povray.org>
Folks,
www.povray.org is back up but without the database. hof.povray.org is
back as it didn't need a database. other sites (e.g. irtc) aren't back
yet, I will get to them next.
If you feel inclined please have a poke around the site to see if you
can see any breakages that aren't related to the DB not being up or
related sites being down (e.g. news.povray.org won't connect). Other
than that it should work. If you see any completely blank pages (as
opposed to connect failures) on the site then that's likely a PHP error;
please LMK.
It will take some time to audit all the PHP code for side-effects as
we've gone from PHP5 to PHP7 (plus all the database calls have to be
changed as the mysql driver was dropped in favor of mysqli in PHP7).
Also please note the mail server isn't back up, so any mails to
povray.org will not go through. (Technically it is up and working, but
the spam filtering isn't back in place and I don't dare open it up to
the world until it is as I'd be swamped).
-- Chris
Date: 15 Mar 2021 10:24:49
Message: <604f6e31$1@news.povray.org>
i knew there would be some pain there... i suppose that's why i'm not
getting any response from wiki yet.
Date: 15 Mar 2021 11:12:50
Message: <604f7972@news.povray.org>
That's a whole different kettle of fish, unfortunately. The wiki, texlib
and a few other things run in FreeBSD jails (an OS/process abstraction)
that have their own completely separate set of files (basically the
entire operating system). While I technically could try running them
as-is (iffy as we've gone from 32 to 64-bitOS) it's certain that there
would be a bit of mucking around. If I decide to upgrade them to the
latest tools then all the PHP code in there has to be audited as well.
Realistically, for the wiki, unless it's possible to force it to run
with the old php and apache binaries, we'd have no choice but to upgrade
the entire mediawiki codebase to something current as it's way to big to
manually audit/change each place the database is used.
-- Chris
Date: 15 Mar 2021 13:04:15
Message: <604f938f$1@news.povray.org>
last time i touched wikidocgen i was running php7 on my machine so i
have /some/ confidence, however i've not kept up with mediawiki changes
so i don't know what's in store for that... i'm most fearful of table
name changes. didn't that bite us in the ass last time we upgraded?
we /do/ have a most recent sql dump correct? i haven't ran a mediawiki
on my machine in a while. do you think there's some value in seeing if i
can get that running to see if we can even get it to import?
i would be surprised if the former... i /think/ we both know where this
is going
Date: 15 Mar 2021 18:33:42
Message: <604fe0c6$1@news.povray.org>
Your memory is likely better than mine, so perhaps there were. I hope
there'd be some sort of upgrade script if so.
We have a backup of the DB (not a dump specifically, just the physical
DB directory). While I have yet to bring up mysql I don't anticipate
problems.
Yes, that would be great. I'll get the DB back running and do a dump of
all the tables once the machine has been moved back to the data center
(hopefully shortly). At the moment it's sitting in an office and has
limited outbound bandwidth.
-- Chris
Date: 16 Mar 2021 10:57:32
Message: <6050c75c$1@news.povray.org>
>> changes so i don't know what's in store for that... i'm most fearful
>> of table name changes. didn't that bite us in the ass last time we
>> upgraded?
> problems.
>> i can get that running to see if we can even get it to import?
> -- Chris
ok i did some poking around... first off i'm 2 minor rev's behind on my
opsys and i need to keep it there for the time being, so i think
mediawiki v1.33 is the best i can do (v1.35 is the current supported)...
mainly because i'm at php7.2.5
https://en.wikipedia.org/wiki/MediaWiki_version_history
worth continuing?
