POV-Ray : Newsgroups : povray.general : Tree Example in TreeDesigner causes POV to crash? Server Time
28 Mar 2026 02:02:16 EDT (-0400)
  Tree Example in TreeDesigner causes POV to crash? (Message 1 to 2 of 2)
Subject: Tree Example in TreeDesigner causes POV to crash?
Date: 21 Jul 1998 07:31:10
Message: <01bdb4ac$60c15720$6101a8c0@dreams>
I'm using the TreeDesigner final beta (4) and POV for Windows 3.0.  I
exported the Tree example that came with TreeDesigner as a scene the tried
to parse it and I get the following error :
PVENGINE caused an invalid page fault in
module PVENGINE.EXE at 0157:0049f1aa.
Registers:
EAX=00fe0008 CS=0157 EIP=0049f1aa EFLGS=00010246
EBX=00000006 SS=015f ESP=00fe0000 EBP=00fe0040
ECX=0000080c DS=015f ESI=fffffffb FS=222f
EDX=00fe001c ES=015f EDI=00000004 GS=0000
Bytes at CS:EIP:
55 56 57 51 53 52 89 c6 29 d2 29 c9 29 c0 8a 06
Stack dump:
004891d7 00000000 39323234 00003631 00000000 00000000 00000000 00000000
00000000 00000005 00000000 00fe0057 00000007 00fe00f4 00000000 00fe00a0
After this I have to close the application.  I'm not using the updated
version of POV because it doesn't work with network paths (\\computer\dir).
 The error is only with this data file, other scenes work ok.  Any ideas?
Subject: Re: Tree Example in TreeDesigner causes POV to crash?
Date: 21 Jul 1998 09:54:02
Message: <35b48f6a.0@news.povray.org>
Justin wrote in message <01bdb4ac$60c15720$6101a8c0@dreams>...
[snip]
Did you change anything in TreeDesigner before exporting (rotation, zoom,
leaftypes, etc.)? Which sizing-factor did you use?
Without any changes (no rotation etc.) and sizing-factor 1 I had no problems
rendering the exported file with POV 3.02 on NT (of course no problems
*with* changes either ;-) so I guess the problem is with POV.
More infos for people looking into a possible POV fault:
The exported script contains lots of unions and differences of spheres,
cylinders, cones and prisms (linear_sweep, linear_spline), plus a few very
basic textures and scale, translate, rotate and matrix manipulations.
Johannes.
