Hey there everyone, i ve got what seemed to me like a pretty basic problem.
I have a while loop going and want it to draw a series of spheres. How can
i
get it to pick a random color out of four which i determine.?
Im trying to use a switch statement like this but obviously not working.
#declare loop_iterator = 0
#while (loop_iterator <= (4 * PI))
#declare color1 = Orange
#declare color2 = Green
#declare color3 = Yellow
#declare color4 = Blue
#declare cx = Black
#declare cy = Black
object
#switch (s1)
#case (0)
cx = color1
#case (1)
cx = color2
#case (2)
cx = color3
#case (3)
cx = color4
#switch (s2)
#case (0)
cy = color1
#case (1)
cy = color2
#case (2)
cy = color3
#case (3)
cy = color4
sphere { <sin(loop_iterator),loop_iterator,loop_iterator>, 1 pigment {
Sapphire_Agate } }
sphere { <sin(loop_iterator) -5,loop_iterator,loop_iterator>,1 pigment {
color Yellow } }
#declare loop_iterator = loop_iterator + 2
Can anyone help?
thanks in advance
Zack Halbrecht
Head Procrastinator
Rutgers University
zac### [at] eden rutgers edu
Zack,
Somewhere before your loop you need to seed a random generator:
#declare R1 = seed(0)
In your switches you need the rand function:
#switch (int(rand(R1)*3.999999 )) // gives 0 to 3
Then you need to use your cx and cy values to set the colors for your spheres.
Also I noticed your syntax is not what POV is expecting. It needs to see lines
like:
#declare color1 = pigment{Orange}
and
#case (0)
cx = pigment{color1}
then you can set your colors like this:
cx } }
I hope this helps.
Bill Bohan
http://www.dhc.net/~bilbohan
As many programmers as there are, that's how many ways there are to do it.
> i
I suggest using the rand() function (assuming you're using POV 3) combined
with a switch (too tired now to check the syntax in the docs, but sure it
lays there):
#declare loop_iterator = begin_iterator
#while (iterator < end_iterator)
#declare A = rand()
#declare B = rand()
#switch (A)
#range (0,0.25)
#declare cx = colour Orange
#break
#range (0.25,0.5)
#declare cx = colour Green
#break
#etc...
#switch (B)
#same here
#sphere { ... texture { pigment { colour cx } } }
#sphere { ... texture { pigment { colour cy } } }
#declare iterator = iterator + increment
#end // #while ()
Happy ray-tracing,
B-o-b.
--+* Roland « B-o-b » Mas *+--
bob### [at] casimir rezel enst fr -- Linux, POV-Ray, LaTeX
