"Bald Eagle" <cre### [at] netscape net> wrote:
once I fix the issue with the end caps, then I
> > will begin to run some comprehensive tests. (*)
> Well, that took way longer than it should have.
The issues here were that it was unclear how and when each function should be
called, and in what order.
There were some issues with the signs of normals and dot products.
And then there was the issue with hits on the end cap that should have replaced
the hit on the infinite cylinder.
And clipping of the edge between the cylinder end cap was leaving residual hits.
So there were 4 places that I needed to add code to undef the results of the
infinite cylinder intersection test.
After that, I kinda needed to write a 3rd macro to take everything and assemble
the output of the 2 macros.
A cautionary tale here is that you have the math and geometry, the code that you
write to do it all, and then the code that you write to interpret and visualize
the result.
Don't go chasing bugs in the first two parts, if the problem is in the third
part.
> However, now I just have to debug the function call and subsequent calculations,
> and I'm hoping to get an actual homemade render soon.
That might not get done until the weekend, when I have another 5 straight hours
to scroll back and forth through the code, inventing new expletives until I
finally get something to work.
Stage One is where all of the things in the code get pondered and picked at.
Even if it's the code I wrote myself.
Stage Two is where a "sense" of deeper understanding starts to occur, and one
starts to gain traction, where the parts of the code that really matter start to
be modified and manipulated in a such a way that you can tell that that's where
much of the solution lies.
Stage Three is where you're probably on the edge of giving up, and just make the
decision to spend another 1-2h just trying to push ahead. Weird things happen.
It seems like code gets edited and restored in an unproductive circle, yet
somehow something happens that nudges it forward. Then some key debugging
output coupled with new tests and sections of code finally lead you down the
path to success.
Stage Three is where it ALL happens. DO IT.
- BE
Just briefly scanning this over (as I was up late making rapid-fire changes) and
I noticed that the parser allowed and didn't complain about:
#local in2 = #local Result = {EcResult [2], EcResult [4]};
So who know what other wacky constructs it will let slip through.
Anyway, fixing 2 such statements allowed me to render this stunning grey
rectangle, which I'm assuming must be my cylinder.
- BW
Download 'sdl_raytracer cylinder test.png' (2 KB)
Preview of image 'sdl_raytracer cylinder test.png'
Seeing how exciting that last post was, let me now slay you with a diagram of
what's going on in that paper.
Download 'graphicsgemslinecylinderintersection.png' (195 KB)
Preview of image 'graphicsgemslinecylinderintersection.png'
On 10/24/25 05:02, William F Pokorny wrote:
> I think the normalization - including y - is necessary for other reasons
> like the generation of the polynomials, but I also believe I see your
> point about what is needed for the initial bounding cylinder check,
> specifically. I'll try with branch-off code which drops the 'y'
> component for the initial cylinder test only.
See the attach code excerpt file for what I've settled upon for the
changes.
> Aside: I'd make a moderate bet this tangled with the issues I had in
> some rotation about x tests where parts (partial segments/intervals) of
> the sor would drop out. IIRC, those tests included negative on curve
> (between end control points, points). We'll see.
Lost my bet here.
Bill P.
Download 'sorcodeupdate.cpp.txt' (3 KB)
> I think it's good enough to begin testing the Catmull-Rom bounding.
Here's what I presently have in terms of computing per-segment bounding
cylinders.
Now I just need to code up some bounding cylinder intersection tests to see what
happens.
> Also, there is a mouse in my kitchen.
I have adopted a local stray.
No mouse, but now there is a cat that gets onto my kitchen counter. :|
Am I winning yet?
- BE
Download 'cr_2d_demo.png' (54 KB)
Preview of image 'cr_2d_demo.png'
