"jr" <cre### [at] gmail com> wrote:
> having just read your follow-up, it seems that the interpolation "loose end"
> needs to be sorted. if then you can provide a (working) "worked example" and
> (brief ;-)) explanation, we can update that part of the documentation.
I'll try to get it worked out, unless someone else manages to do it before me.
I just had some success following up on a hunch that the spline is a Catmull-Rom
type.
https://qroph.github.io/2018/07/30/smooth-paths-using-catmull-rom-splines.html
https://www.cs.cmu.edu/~fp/courses/graphics/asst5/catmullRom.pdf
https://andrewhungblog.wordpress.com/2017/03/03/catmull-rom-splines-in-plain-english/
-BW
This last one seemed to be pretty straightforward to follow, and I managed to
implement it in Excel.
So hopefully I'll be able to get the SDL to work tonight.
- BW
I suppose that my next logical question is:
the sor documentation states, "The intersection test with a SOR object involves
solving a cubic polynomial while the test with a lathe object requires to solve
a 6th order polynomial" ...
but upon reviewing the lathe documentation, one can choose between a variety of
different spline types.
So perhaps that needs some clarification / correction / expansion.
(I've also written a Newton-Raphson root solver, and so probably should
investigate the Sturmian root solver.)
- BW
It took longer than i thought, because in order to make the f(h) equation match
the documentation, I had to flip everything upside down and backwards from the
way I did it in Excel. And I used arrays.
But it all works, which is what I needed to do.
With regard to POV 4.0, I see no reason why the number of points needs to be
specified, since the source can count the points when parsing the SDL.
There ought to be a way to specify the "tension" like in a proper Catmull-Rom
spline.
Anyway, here ya go.
- BW
Download 'surface of revolution documentation.png' (62 KB)
Preview of image 'surface of revolution documentation.png'
> needs to be sorted.
So, I just wrote the whole thing from scratch, the way it seemed to me to work,
according to that last linked Wordpress page.
https://wiki.povray.org/content/File:RefImgCurvmath.png
Looks like it was made, or at least uploaded by Jim Holsenback.
I can likely provide a "mathematical" or a code example - either as the vector *
matrix form, or as the intermediate result (A, B, C, & D).
There are some YT videos that seem to go over the topic, so perhaps I can either
use on of those, or dig up the original paper by Catmull and Rom to show the
derivation, and why the vector and matrix values are what they are.
In typical fashion, I can expand all that to simulate / demonstrate how that
curve gets wrapped around the axis to make the "sor" object (both
graphically/geometrically and mathematically), as well as render it as a
parametric {} and an isosurface {}. Easy enough to do that as a union of
triangle{}s, perhaps mesh {}, less likely mesh2{}.
I already edited the doc page in OpenOffice as a first rough draft, however it
may need revision after I at some point figure out exactly what's going on with
the lathe {} object.
As with all things, I'd like to see some level of clarity, completeness, and
comprehensiveness in our documentation. So, in my mind, I would like to see
POV-Ray serve as a repository of computer graphics education that clearly and
completely explains all of the historical and current concepts in computer
graphics, with references, working code, and of course eye-popping artistic
renders.
So perhaps we can make a list of all of the various different kinds of splines,
and see if we can't get as many of them implemented as is practical. I know
Jerome worked out Rational Bezier Splines a while back, and TOK has NURBS worked
out. Even though none of it is in source, it can be implemented via
macros/include files, and in a way, that's a better educational resource that
people can refer to.
* Because we need to attract more people here to spur further development *
- BW
P. S.
With regard to the "equations as images" that we have in ours docs, I'd like to
see some level of plain text version that can be copy/pasted. Or if there is
some way, perhaps we can have MathJax implemented so that we can have great
looking equations.
This covers the basics,
but Wikipedia shows that there are uniform, chordal, and centripetal forms as
well.
(granted for our present purposes, I think we are just using the uniform version
with a tension of 1.0 )
hi,
> looking equations.
I'll reply tomorrow (Sunday), via email, on topic. on the above, the wiki has a
math extension installed, perhaps that should enable you to write the equations
"in text" (see attached).
regards, jr.
Download 'screenshot 2025-08-16 07.02.03.png' (34 KB)
Preview of image 'screenshot 2025-08-16 07.02.03.png'
Well, before I go changing the documentation for POV-Ray, I'd like to point out
that currently I have only worked out some form of the Catmull-Rom spline that
seems to work in a predictable way.
I'm currently at the state where I'm looking at the source code in sor.cpp to
try and figure out if the 2 things match in some way.
https://github.com/POV-Ray/povray/blob/master/source/core/shape/sor.cpp
1. The source uses the x and y values of the control points separately in the
terms of the equations used to solve for the coefficients. I do not.
2. The source uses powers of the control point y values in the matrix, whereas I
do not.
3. The source performs a matrix inversion before calculating the coefficients.
No idea why, or what that does (yet).
4. Then there are other adjustments after that,
c[0] = 3.0 * A;
c[1] = 2.0 * B;
c[2] = C;
5. and then they somehow need to "solve a polynomial" - presumably to find a
root.
n = Solve_Polynomial(2, c, r, false, 0.0, stats);
6. then this n value is used as the iterator in the interpolation
while (n--)
if ((r[n] >= y[0]) && (r[n] <= y[1]))
x[n] = sqrt(r[n] * (r[n] * (r[n] * A + B) + C) + D);
Which all seems bewilderingly complex to me, but seems to jive with current
documentation.
HOW that all works is currently beyond me.
It's just a giant big black box.
Somewhere around 2000, it seemed to be beyond Warp as well.
I have some thing to do today and tomorrow, but Maybe I can spin my version
around the y-axis and compare it the actual sor object and see if they're even
close.
- BW
At the moment, everything is looking to more or less ok, there probably only
needs to be a minor amount of clarification and explanation to make the
documentation sufficiently user-friendly.
I added some comments to the source code for sor.cpp
and hopefully I can make a little more progress on comparing my own version
written from scratch to what's going on in source.
There are normal, chordal, and centripetal forms.
I suspect mine is the normal form, and the one in source is centripetal.
(I will need to check source against the following, which I stumbled upon)
https://splines.readthedocs.io/en/latest/euclidean/catmull-rom-properties.html
So the first thing we need to do is set up our system of equations that relates
a cubic interpolation between the START (P1) and END (P2) points of the spline
to the constraints for the data, namely that the spline has to pass _through_
the endpoints, and the tangents at the endpoints for the spline segments are
defined using the additional spline points P0 and P3.
Following along with the comments that summarize the matrix values, it will be
fairly easy to match this up with what is going on in this video:
https://www.youtube.com/watch?v=DLsqkWV6Cag
/* Use cubic interpolation. */
k[0] = P[i+1][X] * P[i+1][X]; // P1.x^2, actual spline start
k[1] = P[i+2][X] * P[i+2][X]; // P2.x^2, actual spline end
k[2] = (P[i+2][X] - P[i][X]) / (P[i+2][Y] - P[i][Y]); // df/dt at
spline start
k[3] = (P[i+3][X] - P[i+1][X]) / (P[i+3][Y] - P[i+1][Y]); // df/dt at
spline end (tangent)
k[2] *= 2.0 * P[i+1][X]; // = 2 P1.x * (P2.x - P0.x)
(P2.y - P0.y)
k[3] *= 2.0 * P[i+2][X]; // = 2 P2.x * (P3.x - P1.x)
(P3.y - P1.y)
w = P[i+1][Y];
Mat[0][0] = w * w * w; // P1.y^3
Mat[0][1] = w * w; // P1.y^2
Mat[0][2] = w; // P1.y
Mat[0][3] = 1.0; // 1
Mat[2][0] = 3.0 * w * w; // 3*P1.y^2
Mat[2][1] = 2.0 * w; // 2*P1.y
Mat[2][2] = 1.0; // 1
Mat[2][3] = 0.0; // 0
w = P[i+2][Y];
Mat[1][0] = w * w * w; // P2.y^3
Mat[1][1] = w * w; // P2.y^2
Mat[1][2] = w; // P2.y
Mat[1][3] = 1.0; // 1
Mat[3][0] = 3.0 * w * w; // 3*P2.y^2
Mat[3][1] = 2.0 * w; // 2*P2.y
Mat[3][2] = 1.0; // 1
Mat[3][3] = 0.0; // 0
One can solve a system of linear equations in a matrix using a number of
different methods.
The source uses the method of finding the matrix inverse, and then multiplying
both sides of the matrix equation by the matrix inverse.
(This is where the over-brief equation in the docs is confusing, without any
other context)
// Now we find the matrix inverse so that we can solve for the coefficients
ax = b
(1/a)*ax = (1/a)*b
(a^-1)ax = (a^-1)b
(a^-1)*x = 1, so
x = (a^-1) b
MInvers(Mat, Mat); // in math/matrix.cpp
// Once we have the matrix inverse, we take the data constraints and the matrix
inverse and
// multiply them to calculate the coefficients.
/* Calculate coefficients of cubic patch. */
// k[] is the column vector of the constraints
// and Mat[] is the *matrix_inverse* M
// so multiplying together equals the column vector of the coefficients
A = k[0] * Mat[0][0] + k[1] * Mat[0][1] + k[2] * Mat[0][2] + k[3] *
Mat[0][3];
B = k[0] * Mat[1][0] + k[1] * Mat[1][1] + k[2] * Mat[1][2] + k[3] *
Mat[1][3];
C = k[0] * Mat[2][0] + k[1] * Mat[2][1] + k[2] * Mat[2][2] + k[3] *
Mat[2][3];
D = k[0] * Mat[3][0] + k[1] * Mat[3][1] + k[2] * Mat[3][2] + k[3] *
Mat[3][3];
I still feel like there should be some minus signs in there to make the
interpolation work - but maybe those pop out the other side of the MInvers () .
.. . I'll have to write that out in SDL and run it to find out.
I also don't quite understand why we need to take the square root of the result
in line 1082
to get the interpolated spline values, but perhaps that may become clear as I
find more bits of time here and the to properly focus on this.
Just wanted to issue a progress report. :)
- BE
Sent values of A-D for each segment to the debug stream, and there are
definitely minus signs.
> in line 1082
This apparently has to do with the value of "alpha" in the interpolation, with 0
being Uniform, 1/2 being Centripetal, and 1 being Chordal.
I'm not really sure where "r" comes from in the source, or how that while loop
interpolates the spline, but I just ignored all of that, and things worked out
anyway. :D
After fixing some boneheaded visualization bugs, the math seemed to be working
out with the spline, so I took my SDL version of the SOR spline and used the X
value (minus the minor radius) as the major radius of a torus, and "plotted" a
torus at each interpolation point. (RED)
Seems to overlay the sor {} object (BLUE) very closely. Errors are probably due
to my janky simulation method, and coincident surfaces.
I'll try to work out the details as I write things up, and I'll probably make a
parametric {} and isosurface {} object to further test how well things match up.
- BE
Download 'surface of revolution documentation.png' (255 KB)
