On 1/6/2018 7:20 PM, Kenneth wrote:
> In 3.6.2.4.2 Image Pattern, it says...
> "Note: This pattern uses an image to get the gray values. If you want exactly
> the same possibilities but need to get gray values from a pigment, you can use
> the --pigment_pattern--."
> That pigment_pattern link is incorrect; it leads to 3.6.1.1.3 Pigment Map
> instead. The correct link should be 3.6.2.1.19 Pigment Pattern.
this was a poorly formed /multi-link/ that i changed to a /single/ link
that goes to the proper place now
