POV-Ray : Newsgroups : povray.documentation.inbuilt : typo in 2.2.1.3 Server Time
19 Apr 2026 05:25:07 EDT (-0400)
  typo in 2.2.1.3 (Message 1 to 1 of 1)
Subject: typo in 2.2.1.3
Date: 19 Feb 2005 15:10:00
Message: <web.42179c133169e396dc761f060@news.povray.org>
Here:
http://www.povray.org/documentation/view/3.6.1/228/
In this:
FLOAT_FUNCTION:
    abs( FLOAT ) | acos( FLOAT ) | acosh( FLOAT ) | asc( STRING ) |
    asin( FLOAT ) | asinh( FLOAT ) | atan( FLOAT) | atanh( FLOAT) |
    atan2( FLOAT , FLOAT ) | ceil( FLOAT ) | cos( FLOAT ) |
    cosh( FLOAT ) | defined(IDENTIFIER ) | degrees( FLOAT ) |
    dimensions( ARRAY_IDENTIFIER ) |
    dimension_size( ARRAY_IDENTIFIER , FLOAT ) |
    div( FLOAT , FLOAT ) | exp( FLOAT ) | file_exists( STRING ) |
    floor( FLOAT ) | int( FLOAT ) | ln(Float | log( FLOAT ) |
    max( FLOAT , FLOAT, ... ) | min( FLOAT , FLOAT, ... ) |
    mod( FLOAT , FLOAT ) | pow( FLOAT , FLOAT ) |
    radians( FLOAT ) | rand( FLOAT ) | seed( FLOAT ) |
    select( FLOAT, FLOAT, FLOAT [,FLOAT]) | sin( FLOAT ) |
    sinh( FLOAT ) | sqrt( FLOAT ) | strcmp( STRING , STRING ) |
    strlen( STRING ) | tan( FLOAT ) | tanh( FLOAT ) |
    val( STRING ) | vdot( VECTOR , VECTOR ) | vlength( VECTOR ) |
    FLOAT_BUILT-IN_IDENT:
    clock | clock_delta | clock_on | false | final_clock |
    final_frame | frame_number | initial_clock | initial_frame |
    image_width | image_height | no | off | on | pi | true |
    version | yes |
I think there are two superfluous | symbols, one at the very end, and one
before FLOAT_BUILT-IN_IDENT. And the latter shouldn't be indented if I
understand it right.
