POV-Ray : Newsgroups : povray.documentation.inbuilt : Documentation Sources Server Time
12 Jul 2025 08:16:15 EDT (-0400)
  Documentation Sources (Message 1 to 2 of 2)
Subject: Documentation Sources
Date: 2 Nov 2004 18:50:01
Message: <web.41881c447d05d5e2b6303d850@news.povray.org>
Does anybody know where the original sources for the documentation are? I
keep seeing references to 'makedocs.pl' in the unix source tree
(docs/*.html), but I can't find either the script or the master
documentation.  Shouldn't it be around somewhere?
Chris
Subject: Re: Documentation Sources
Date: 3 Nov 2004 02:35:02
Message: <cm96tn$htk$1@chho.imagico.de>
If you find references to makedocs.pl in the POV-Ray for Unix
documentation you are using an outdated version of POV-Ray (makedocs.pl
was only used in POV-Ray 3.5).
The program used to generate the html/pdf/etc. version of the docs is
not available so it does not make sense to make available the docs
source files either.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
