POV-Ray : Newsgroups : povray.documentation.inbuilt : dictionary container types Server Time
18 Oct 2026 12:53:55 EDT (-0400)
  dictionary container types (Message 1 to 19 of 19)
Subject: dictionary container types
Date: 19 Nov 2016 10:38:36
Message: <583071fc$1@news.povray.org>
from discussion Classes/containers in sdl? in p.advanced-users i know
for a fact that this hasn't been added to docs either ... it was
mentioned that the syntax is still in flux. i just wanted to post here
as a reminder to follow up. @Bill ... would you mind following up with a
link so i can have a look at what we have so far and /maybe/ get started
on that ... thanks in advance
Subject: Re: dictionary container types
Date: 19 Nov 2016 14:26:53
Message: <5830a77d$1@news.povray.org>
Am 19.11.2016 um 16:38 schrieb Jim Holsenback:
It's not in the main branch yet, so should probably not be added to the
docs yet; however, for the records:
Arrays will be modified as follows:
- Array elements will no longer have to be all of the same type.
- Caveat: Mixing elements of different type will increase memory
consumption; the increased memory footprint will not revert even if the
array is later set to elements all of the same type.
- An array can be declared without specifying any dimensions; in this
case the array will be one-dimensional and be able to grow in size
dynamically.
- Accessing an element beyond the nominal size of such an array will
automatically increase the nominal size just enough to include that element.
- Caveat: The memory footprint may be twice as high as required for the
current nominal size.
- Caveat: Growth of such an array is triggered by /any/ access to an
element beyond the nominal size; this includes tests such as
`#ifdef(ARRAY[INDEX])`.
Also, so-called "dictionaries" will be added, i.e. containers that map
string keys to arbitrary-type values; if the syntax remains as currently
implemented, it will be as follows:
    // create an empty dictionary
    #declare Fnord = dictionary;
    // create a dictionary with elements
    #declare Fnord = dictionary {
      ["Foo"]: 42,
      ["Bar"]: sphere { <0,0,0>, 1 }
    // alternative
      .Foo: 42,
      .Bar: sphere { <0,0,0>, 1 }
    // access a dictionary element
    #declare Fnord["Foo"] = 42;
    #declare Answer = Fnord["Foo"];
    // alternative
    #declare Fnord.Foo = 42;
    #declare Answer = Fnord.Foo;
    // testing whether a dictionary contains a particular key
    // (e.g.)
    #ifdef (Fnord.["Foo"]) ... #end
    #declare FooKeyExists = defined(Fnord.Foo);
    // removing a key from a dictionary
    // (e.g.)
    #undef Fnord["Foo"];
When using square bracket notation, the keys do not necessarily have to
be string literals, but can be arbitrary string expressions.
When using dot notation, the indices must follow the generic rules for
identifiers.
Date: 19 Nov 2016 18:18:55
Message: <5830dddf$1@news.povray.org>
Am 19.11.2016 um 20:26 schrieb clipka:
BTW, the syntax can be test-driven with this version:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-x.dictionary.8877243
Date: 19 Nov 2016 19:10:11
Message: <5830e9e3$1@news.povray.org>
On 11/19/2016 2:26 PM, clipka wrote:
>     // alternative
>       .Foo: 42,
Will the dotted syntax allow people to use strings like ".declare" or
".texture"? I don't think it should.
Mike
Date: 19 Nov 2016 19:34:31
Message: <5830ef97$1@news.povray.org>
Am 20.11.2016 um 01:10 schrieb Mike Horvath:
>>     // alternative
>>       .Foo: 42,
No -- just like with variable identifiers, keywords are not allowed there.
Date: 22 Nov 2016 02:31:45
Message: <5833f461$1@news.povray.org>
>     // (e.g.)
Of course that should be
    #ifdef (Fnord["Foo"]) ... #end
Date: 22 Nov 2016 02:35:40
Message: <5833f54c$1@news.povray.org>
>>>     // alternative
>>>       .Foo: 42,
I still think the dot is superfluous.
Mike
Date: 22 Nov 2016 17:25:11
Message: <5834c5c7$1@news.povray.org>
> for the records:
thanks for that ... i went ahead and created a talk page:
http://wiki.povray.org/content/Reference_Talk:Array
i still need to work the new keyword into the syntax diagram and do an
overall review of the rest of the page ... go ahead and work over there
if you want to make any changes
Date: 23 Nov 2016 07:11:32
Message: <58358774$1@news.povray.org>
>> for the records:
finished page clean up and made a stab at the syntax diagram ... please
review that to make sure that i haven't forgotten or mis-characterized
anything
Date: 23 Nov 2016 10:04:44
Message: <5835b00c$1@news.povray.org>
Am 23.11.2016 um 13:11 schrieb Jim Holsenback:
>>> for the records:
> anything
Array:
"[...] IDENTIFIER is the name of the identifier up to 40 characters long
That's outdated; there is no hard-coded limit for the length of
identifiers anymore.
"Large uninitialized arrays do not take much memory. Internally they are
arrays of pointers so they probably use just 4 bytes per element"
We should probably update that to "8 bytes per element", to account for
the rise of 64-bit machines.
Dictionary:
The DICTIONARY_DECLARATION syntax implies that a DICTIONARY_INITIALIZER
can only be specified with #declare, not with #local. That is not true:
Both #declare and #local allow for a DICTIONARY_INITIALIZER.
The DICTIONARY_ITEM syntax implies that it can be a
DICTIONARY_INITIALIZER; this is also wrong. The corresponding portion of
the array syntax accounts for the nested initializers of
multi-dimensional arrays, but dictionaries always have just one dimension.
The DICTIONARY_ENTRY syntax implies that it can only be an int, float or
string. This is not the case: Anything you can shove into an array can
also be shoved into a dictionary.
The changes to array syntax and behaviour don't fit into the
"Dictionary" section; they should instead be in the "Array" section.
Date: 23 Nov 2016 11:43:34
Message: <5835c736$1@news.povray.org>
thanks for keeping me honest:
Date: 23 Nov 2016 12:17:17
Message: <5835cf1d$1@news.povray.org>
Am 23.11.2016 um 17:43 schrieb Jim Holsenback:
I think I got you confused.
The information I provided in the earlier post was for the entire bundle
of changes in the `feature/dictionary` branch currently waiting to be
tested and merged. The branch has grown to become somewhat of a
misnomer, and `feature/containers` would be a more fitting name by now,
as besides introducing the new `dictionary` container type it also
contains improvements to the classic old-school integer-indexed `array`
container.
All the information you put in the numbered-list section starting with
"Array elements will no longer have to be all of the same type [...]"
applies to arrays, not dictionaries.
It's ok (and, if I am asked, desirable) to have the dictionary-related
stuff in a separate section.
Also, typo:
"There has been a Change that removes than restriction."
I'm also noticing right now that the comments in the example section are
a bit inconsistent; please replace "testing" and "removing" with "test"
and "remove".
Date: 23 Nov 2016 13:27:26
Message: <5835df8e@news.povray.org>
no doubt ... back when all this happened i was /not/ following the
goings on, but now i'm finding time to get caught up.
Date: 24 Nov 2016 09:08:01
Message: <5836f441$1@news.povray.org>
lol ... ok enough with the back-and-forth already ;-)
not sure why i kept wanting to treat as two different subjects ...
hopefully i've cleared things up:
http://wiki.povray.org/content/Reference_Talk:Array and we can stick a
fork in this one!
Date: 24 Nov 2016 10:01:33
Message: <583700cd$1@news.povray.org>
Am 24.11.2016 um 15:07 schrieb Jim Holsenback:
> fork in this one!
Almost there.
"Additional points to consider are as follows:"
- Please add a note that this is new in 3.7.1. ;)
- I'd remove the "will" from "1. Array elements will no longer...".
- I'd collapse 1.a and 1.b into a single paragraph.
- I'd collapse 3.b and 3.c into a single paragraph.
- I'm noticing only just now that points 4. and 5. apply only to
dictionaries. I think something should be done to make this clearer.
- I'm noticing only just now that 6. is a duplicate of 4.
- I'd add a few end-of-sentence markers (aka full stops) to the items. ;)
- I'd personally prefer a bullet list, as there's no hierarchy among the
items.
Also, I'd move anything related to dictionary initializers to the "Array
Initializers" section, possibly with a line of text or two.
Date: 25 Nov 2016 07:00:36
Message: <583827e4$1@news.povray.org>
>> fork in this one!
> Almost there.
argh ... you're stifling my creativity ;-)
Date: 13 Dec 2016 04:17:02
Message: <584fbc8e$1@news.povray.org>
Am 22.11.2016 um 08:35 schrieb Mike Horvath:
>>>>     // alternative
>>>>       .Foo: 42,
>> there.
Think about it:
    #declare Foo = "Dang";
    #declare Bar = "What";
      Foo: 42,
Which of the following would that supposedly be equivalent to?
(A)
    #declare Fnord.Bar = sphere { <0,0,0>, 1 }
(B)
    #declare Fnord[Foo] = 42;
    #declare Fnord[Bar] = sphere { <0,0,0>, 1 }
aka
    #declare Fnord.Dang = 42;
    #declare Fnord.What = sphere { <0,0,0>, 1 }
I think mandating the dot is a nice way to prevent such ambiguity; plus,
it makes things a tiny bit more consistent: Whatever you'd normally put
after the dictionary identifier, you just pop it into the initializer.
Date: 13 Dec 2016 05:00:06
Message: <584fc6a6$1@news.povray.org>
Am 13.12.2016 um 10:17 schrieb clipka:
> Think about it:
>       Foo: 42,
To elaborate more on that point: When designing the syntax for
dictionary initializers, one could come up with the following
alternatives to all denote the same:
(Intent)
    #declare Fnord["Bar"] = sphere { <0,0,0>, 1 }
(A)
      Foo: 42,
(B)
      "Foo": 42,
      "Bar": sphere { <0,0,0>, 1 }
(C)
      .Foo: 42,
(D)
      ["Foo"]: 42,
Note how variants (A) and (B) are fundamentally incompatible: If the key
can be a string literal, it is legitimate to also expect other string
expressions to work, and this would include plain references to string
variables. Thus, a consistent implementation of (B) would also allow for
the following:
    #declare Key1="Foo";
    #declare Key2="Bar";
      Key1: 42,
      Key2: sphere { <0,0,0>, 1 }
This however would take on a completely different meaning under variant (A).
Now one could rule in favour of either A or B, and I think both have
their merits. Which is why I think it wise to go for neither of them,
and instead opt for variants that are collision-free not only with
respect to each other, but even with respect to the entire set of
_possible_ alternatives.
Date: 13 Dec 2016 05:43:39
Message: <584fd0db$1@news.povray.org>
Am 13.12.2016 um 11:00 schrieb clipka:
> (A)
>       Foo: 42,
> (C)
>       .Foo: 42,
Here's another case study showing how (A) might be disadvantageous:
    #declare Value = "Bar";
    #declare Fnord.Foo = Value;
In (A) notation, the equivalent would be:
      Foo: Value
But if the identifier `Value` on the right-hand side is evaluated to
"Bar", wouldn't a user also expect, with some legitimacy, the identifier
`Foo` on the left-hand side to be evaluated in the same manner? Thus, a
user may be fooled into expecting the following to work:
    #declare Key = "Foo";
      Key: Value
In (C) notation, it would instead be:
      .Foo: Value
Here, the mandatory dot gives the user a hint that there is /something/
different about the way the two identifiers act.
There's also another, much more far-reaching rationale to pick the dot
notation: Some day or another we'll want to overhaul the entire Scene
Description Language, and replace it with something similar but more
powerful while at the same time much more self-consistent.
One part of the deal would be to demote parameters (such as the
"diffuse" in the "finish" block) from reserved keywords to something
much more akin to "variables". We would also want users to be able to
define their own data structures that behave in exactly the same way, so
that users might e.g. define their own parameterizable geometric shapes.
However, in such a world it could become increasingly difficult to tell
apart parameters from genuine variables - and one possible solution to
that problem might lie in adopting the dot notation for parameters,
while using "undotted" identifiers for variables defined elsewhere; e.g.
a finish definition might end up looking like this:
    finish {
      .diffuse:    rand(R);
      .specular:   1 - .diffuse;
      .reflection: .specular * ReflectionFactor;
Looking familiar? ;)
