POV-Ray : Newsgroups : povray.documentation.inbuilt : looks_like suggestion Server Time
19 Mar 2026 15:29:32 EDT (-0400)
  looks_like suggestion (Message 1 to 10 of 25)
Subject: looks_like suggestion
Date: 8 Sep 2016 00:46:20
Message: <57d0ed1c$1@news.povray.org>
http://www.povray.org/documentation/view/3.6.2/137/
On this page it says:
"It is a good idea to define both things, the light source and the
looks_like object, at the origin, and then translate them to their right
place."
However, this is *not* a good idea for parallel light sources. Doing so
causes the light to emit from the light source's original position (the
origin) instead of the later position.
Subject: Re: looks_like suggestion
Date: 8 Sep 2016 00:49:26
Message: <57d0edd6$1@news.povray.org>
> place."
Oops. I didn't realize the reference was for an old versions of POV-Ray.
I have no idea if the newer reference has fixed this mistake or not.
Mike
Date: 8 Sep 2016 00:58:37
Message: <57d0effd$1@news.povray.org>
> place."
http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_4_1_7
This section only shows an example of how *not* to properly set up the
looks_like section. It should explain how to do it *correctly* too. But
I don't know what is correct.
Mike
Date: 8 Sep 2016 17:14:53
Message: <57d1d4cd@news.povray.org>
>> place."
> Mike
The looks_like object is always centered at the light's location.
So, you should create your light_source at any location while
constructing the looks_like object around the origin.
Date: 8 Sep 2016 18:07:29
Message: <57d1e121$1@news.povray.org>
>>> place."
>> Mike
Can I update the wiki page with the additional information? I already
have a wiki account, and am logged in, but the article is locked.
Mike
Date: 8 Sep 2016 18:28:51
Message: <57d1e623@news.povray.org>
Am 09.09.2016 um 00:07 schrieb Mike Horvath:
You should be able to post the suggested new wording on the respective
"Discussion" page; if it's ok, Jim can copy it from there.
Date: 8 Sep 2016 18:51:09
Message: <57d1eb5d$1@news.povray.org>
Okay, I suggested my changes here:
http://wiki.povray.org/content/Reference_Talk:Light_Source
Mike
Date: 11 Sep 2016 08:40:40
Message: <57d550c8$1@news.povray.org>
Well that section was awkward to begin with ... since it was so short I
just rewrote the whole thing:
http://wiki.povray.org/content/Reference:Light_Source#Looks_Like
I also renamed /that/ and one other section for consistency reasons
Date: 11 Sep 2016 09:45:19
Message: <57d55fef$1@news.povray.org>
Am 11.09.2016 um 14:40 schrieb Jim Holsenback:
I find "important things to consider" item 5 quite confusing: Is it
intended to apply to a regular looks_like object, or the union alternative?
Personally I'm quite sure it's the latter, but I would suggest to
instead use wording like:
    4. use a union instead if you want the object to
       block light (remember to make /some/ portion of
       the object transparent)
Also, the union example is broken, as in contrast to looks_like the
union doesn't auto-translate My_Lamp_Shape to the location of the light
source.
Date: 11 Sep 2016 10:22:54
Message: <57d568be$1@news.povray.org>
well the union example of course! i DID have "and ..." as #4 then "..."
at the beginning of #5
LOL ... fixed it
> source.
done and done
