POV-Ray : Newsgroups : povray.documentation.inbuilt : Bad indexes for transforms Server Time
24 Jun 2026 06:59:46 EDT (-0400)
  Bad indexes for transforms (Message 1 to 8 of 8)
Subject: Bad indexes for transforms
Date: 14 Nov 2009 23:09:48
Message: <4aff7f0c$1@news.povray.org>
I'm using 3.6.1.
The index entries for most of the transform keywords point only to the
quickref. They should point to better locations with actual text
descriptions. Separate links to the quickref are OK, as long as they are
nested underneath the main links in the index.
Mike
Subject: Re: Bad indexes for transforms
Date: 14 Nov 2009 23:15:11
Message: <4aff804f@news.povray.org>
On 11/14/2009 11:09 PM, SharkD wrote:
> I'm using 3.6.1.
> Mike
Also, the index entries for "transform", "transformations" and
"transformations > quickref" all lead to the quickref entry.
Mike
Date: 15 Nov 2009 05:01:22
Message: <4affd172@news.povray.org>
"SharkD" <mik### [at] gmailcom> wrote in message
news:4aff7f0c$1@news.povray.org...
> I'm using 3.6.1.
Thanks for all your hard work, however your post is a bit lacking ....
I'm back writing the code to pull this stuff back out of the wiki and I
don't have time to go digging. If you would create a talk page (not the
entire page ... just the section(s)) were you've spotted the above mentioned
that would be immensely helpful.
Jim
BTW: Your post about "Operators" was equally confusing .... if you wouldn't
mind following up in kind, I'd appreciate it!
Date: 15 Nov 2009 07:04:09
Message: <4affee39$1@news.povray.org>
> I'm using 3.6.1.
> Mike
redirected the rotate, scale and translate links in this section:
http://wiki.povray.org/content/Documentation:Reference_Section_2#Identifiers_and_Keywords
zat what yer talkin' bout?
Jim
Date: 15 Nov 2009 15:04:46
Message: <4b005ede$1@news.povray.org>
> Jim
That's certainly an improvement. However, it would be better still if
the index pointed to the actual page where the keyword is described.
For instance, "translate" should point here:
http://wiki.povray.org/content/Documentation:Tutorial_Section_2.2#Translate
Mike
Date: 16 Nov 2009 06:58:01
Message: <4b013e49$1@news.povray.org>
news:4b005ede$1@news.povray.org...
>> Jim
> That's certainly an improvement. However, it would be better still if the
> Mike
yes ... that's what i did with the change mentioned above.
Date: 16 Nov 2009 18:07:09
Message: <4b01db1d$1@news.povray.org>
My original post was with regard to the index of the Windows HTML Help
file, not any links in individual help pages.
Mike
Date: 17 Nov 2009 05:32:45
Message: <4b027bcd$1@news.povray.org>
news:4b01db1d$1@news.povray.org...
> Mike
ok ... so it appears that we've corrected the root of that problem.
coincidently ... been working on the document map section of povdocgen, so
I'll double check to make sure this section has been mapped properly.
Jim
