POV-Ray : Newsgroups : povray.documentation.inbuilt : PDF docs enhancement Server Time
16 Nov 2026 02:18:54 EST (-0500)
  PDF docs enhancement (Message 1 to 5 of 5)
Subject: PDF docs enhancement
Date: 2 Sep 2004 09:08:14
Message: <41371b3e$1@news.povray.org>
I just downloaded the POV-Ray 3.6.1 PDF documentation, which I prefer
over the HTML version because it's easier to search, and found a few
points that I didn't like. So I downloaded the TeX source and fixed them:
o There are no PDF bookmarks for the table of contents, and no
hyperlinks from the table of contents and the index to the text. This
can be fixed by using the hyperref package (together with pdftex, which
you seem to be using as well - I didn't test whether it works with
tex+dvips+ghostscript). This package would also allow including the
in-text hyperlinks, but these are not in the TeX source, so that would
have to be added to your master-to-TeX script. There are lots of
additional options in hyperref that I didn't use, see its documentation.
o I don't like the roman page numbers for the front matter. They're fine
for printed books, but for on-screen navigation they are a little
annoying because they make the printed page numbers go out of sync with
the PDF page numbers. So I removed them. (Of course that's my personal
opinion, and if yours is different, you may just as well leave them in.)
Two problems that I ran into while TeXing, and that were easily fixed:
o In the section "Photon Tips", there are two nested itemize
environments, and TeX doesn't seem to like that. That's probably a bug
in the master source, as it also occurs in the HTML version (but there
it doesn't cause any problems).
o The paths for the figures don't match the actual directory structure
in the downloaded ZIP file. They are like
"../final/tex/images/reference/gamma" when they should be like
"images/reference/gamma".
Here are the actual changes I made to reference-a4.tex (should be easily
adapted to the us-letter format and the tutorial):
----8<----------------------------------
diff -u old/reference-a4.tex new/reference-a4.tex
--- old/reference-a4.tex        Sun Aug  1 13:47:06 2004
+++ new/reference-a4.tex        Thu Sep  2 14:11:14 2004
@@ -69,6 +69,7 @@
  \usepackage{fancyhdr}
  \usepackage{graphicx}
  \usepackage[latin1]{inputenc}
+\usepackage[a4paper, pdftex, hyperindex, bookmarksnumbered,
pdfborder=false]{hyperref}
  \makeindex
@@ -118,7 +119,7 @@
  \date{for POV-Ray Version 3.6.1}
-\title{POV-\discretionary{}{}{}Ray Reference} \pagenumbering{roman}
\maketitle \tableofcontents \listof{figure}{Figures}
\listof{table}{Tables} \cleardoublepage \pagenumbering{arabic}
+\title{POV-\discretionary{}{}{}Ray Reference} \maketitle
\tableofcontents \listof{figure}{Figures} \listof{table}{Tables}
\cleardoublepage
  \clearpage \chapter{Introduction}
@@ -23657,7 +23658,7 @@
  % reference/000327.html
-\begin{itemize}
+%\begin{itemize}
   \begin{itemize}
@@ -23681,7 +23682,7 @@
   \end{itemize}
-\end{itemize}
+%\end{itemize}
  \subsection{Advanced Techniques}
What do you think? Any chances of adding any of these to the official docs?
  -Christian
Subject: Re: PDF docs enhancement
Date: 2 Sep 2004 13:42:35
Message: <41375b8b$1@news.povray.org>
In article <41371b3e$1@news.povray.org> , Christian Walther
Thanks for pointing this out!
Ah yes, this is an artifact of the documentation creation process which uses
these relative pathes.  I suppose adding a note to the TeX documentation
will have to do for this as it would make the doc building even more complex
when two TeX documents would need to be generated and validated, sorry!
We are very well aware of the hyperref package.  As we explicitly state on
the download page, the PDF and PostScript versions of the documentation are
for *printing*.  The printable documentation should obviously not be
cluttered with useless hyperlinks that also destroy the printed version's
layout.
PDF is a document format designed for printing and not for viewing. As such,
usability problems of Adobe Acrobat Reader and similar products when trying
to use PDFs for on screen viewing should be reported to their developers,
not us.
HTML is a hypertext format and if you desire hypertext navigation you should
be using the HTML version, not the documentation for printing! :-)
The Windows and Macintosh HTML documentation is fully searchable by the
respective system help viewers.
    Thorsten
e-mail: tho### [at] trfde
Date: 2 Sep 2004 13:50:07
Message: <Xns9558C9C5E753Aseed7@news.povray.org>
> them:
Christian,
The PDF's of the documentation are intendet for printing only, as each
official distribution comes with a "platform specific" help file for on-
screen use. This is the reason why the first two points in your comment
are the way they are. I doubt they will be changed.
I'll have a look at the two last points.
Thanks,
Ingo
Date: 3 Sep 2004 04:39:31
Message: <41382dc3$1@news.povray.org>
> layout.
How do the hyperlinks destroy the layout? As far as I see my hyperlinked
version of the PDF looks exactly the same as your non-hyperlinked.
> not us.
I should report to Apple that Preview doesn't magically invent the
bookmarks and hyperlinks that aren't present in the PDF? :)
And, well, I probably wouldn't be using the PDF docs if I had to use
Adobe Reader. But Preview is nice. :)
Ah, right, didn't think of that. I always used a web browser, not Help
Viewer. Though I think I still like searching in Preview better than in
Help Viewer.
Anyway, I'm fine with your decisions. After all, I can still use my own
hyperlinked and bookmarked version of the PDF. Just keep the TeX source
available...
  -Christian
Date: 3 Sep 2004 05:25:02
Message: <ch9d7a$37o$2@chho.imagico.de>
And on all other systems you can use:
http://www.tu-bs.de/%7Ey0013390/povdoc/index.html
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
