POV-Ray : Newsgroups : povray.documentation.inbuilt : Finding that function thingy in heightfields Server Time
16 Nov 2026 02:18:55 EST (-0500)
  Finding that function thingy in heightfields (Message 1 to 14 of 14)
Subject: Finding that function thingy in heightfields
Date: 10 Oct 2002 08:53:20
Message: <3da57840$1@news.povray.org>
I remember there's a way to insert a function instead of a bitmap into
heightfields.
My thorough study of the heightfield and function sections of the inbuilt
docs wouldn't allow me to find this.
Perhaps we could drop hints of whatever this is called into at least the hf
docs....
Subject: Re: Finding that function thingy in heightfields
Date: 10 Oct 2002 09:04:56
Message: <3DA57AF2.710BC40A@pacbell.net>
> heightfields.
> docs....
6.5.4.2  Functions in Isosurface
Ken Tyler
Date: 10 Oct 2002 09:17:58
Message: <3DA57E04.C1A0FB8A@gmx.de>
> > heightfields.
> > docs....
6.7.11.16  Function Image
(Ken, are you getting senile? ;-))
I think a note in both the heightfield and the image_map section would be
appropriate.
Date: 10 Oct 2002 09:24:52
Message: <Xns92A39D9A47A02seed7@povray.org>
> would be appropriate.
I want to put all image input-formats into one section, that would include
df3 and function image.
Ingo
Date: 10 Oct 2002 10:12:19
Message: <3DA58ABE.DCBCA4F7@gmx.de>
I'm not sure if that's a good idea, df3 is only used in a pattern
(density_file), but image types are used in heightfields, image_map,
bump_map, material_map, image_pattern and heightfield.
Date: 10 Oct 2002 10:23:08
Message: <3da58d4c@news.povray.org>
> appropriate.
  I have suggested this as well. A note and a link to 6.7.11.16 in both
of those sections would help a lot finding that feature.
  I don't understand how they succeeded in hiding that feature so well... :)
Date: 10 Oct 2002 11:36:26
Message: <chrishuff-8B55AB.11325710102002@netplex.aussie.org>
In article <3da57840$1@news.povray.org>,
> heightfields.
> docs....
It isn't really a "function thingy", it just uses them, and it doesn't
have anything to do with height fields, it is just an image type. Look
for a list of the image types...
http://tag.povray.org/
Date: 10 Oct 2002 14:45:11
Message: <Xns92A3D3E962523seed7@povray.org>
Christoph,
do you mean, don't put the df3 in such a section, or do you mean don't do
it all?
Ingo
Date: 10 Oct 2002 15:27:07
Message: <3DA5D48A.E923E571@gmx.de>
> it all?
I meant to leave out df3.  Otherwise it seems a pretty good idea
(especially if it includes a few hints for the newbies about which image
formats should be preferred for which purpose).
Date: 12 Oct 2002 03:13:23
Message: <Xns92A55E9FC8CACseed7@povray.org>
- Input formats:
   description of all types of input that POV-Ray can deal with,
   except *.pov, *.inc and *.ini files.
   - Image formats:
       - TGA
       - SYS
       - PNG
       - Notes on use
   - Internal formats:
       - function
   - Density formats:
       - DF3
       (- DF/DFD if it will make it into an official)
   (- Font formats ?)
This kind of like the setup I was thinking of, but I havn't finished
these thoughts. "Internal formats" could be indented one more level and
be part of Image formats. Font files could be part of it, or not. Where
in the whole structure of the SDL section does it fit best? etc.
> image formats should be preferred for which purpose).
It will.
Ingo
Date: 12 Oct 2002 05:59:16
Message: <3DA7F274.462B456D@gmx.de>
ingo wrote:
> - Input formats:
How about the radiosity and photons file formats.  They are probably used
much less than image files but documentation would be even more important
since they are specific to POV-Ray so documentation can't be found
elsewhere.
Date: 12 Oct 2002 10:00:09
Message: <Xns92A5A3967B5Cseed7@povray.org>
Ah, good one.
Ingo
Date: 14 Oct 2002 14:46:40
Message: <3dab1110$1@news.povray.org>
In article <3DA7F274.462B456D@gmx.de> , Christoph Hormann
> elsewhere.
Their format is subject to change without notice, so what could be said
about them?
    Thorsten
e-mail: tho### [at] trfde
Date: 14 Oct 2002 16:03:22
Message: <3DAB230A.4C64EC61@gmx.de>
> > elsewhere.
> about them?
Just because the format could be changed does not make a description
obsolete.  In fact i doubt either of these formats will change
significantly (meaning making a description totally worthless) soon.  Both
file formats are strongly bound to the way the data is handled internally
so describing the formats could help understanding how these functions
work too.  Apart from that I have several photons and radiosity files that
took longer to calculate than a lot of image files so i would not be
pleased if POV-Ray would neglect how to read them very soon...
