POV-Ray : Newsgroups : povray.documentation.inbuilt : image function Server Time
26 Sep 2024 19:28:19 EDT (-0400)
  image function (Message 1 to 10 of 18)
Subject: image function
Date: 23 Feb 2002 12:54:24
Message: <ihlf7ug81p1jpggidgh752e2qeiscancpu@4ax.com>
Considering all discusions about antialiasing I think it could be worth to
mention in 6.7.11.16  of new 3.5 documentation: is this image somehow
supersampled or not.
ABX
Subject: Re: image function
Date: 23 Feb 2002 14:40:56
Message: <3c77f048@news.povray.org>
How can an image be supersampled?
Felix
Date: 23 Feb 2002 15:07:22
Message: <chrishuff-6765B9.15071323022002@netplex.aussie.org>
In article <3c77f048@news.povray.org>,
The function image is generated by taking a function (which may be a
pigment function) and sampling its color for each pixel. It would be
possible to take multiple samples per pixel, and get a smoother image...
Date: 24 Feb 2002 17:24:21
Message: <3c796815@news.povray.org>
It is an image generated from a function, how would supersampling even make
sense at all without destroying the purpose the feature?  The obvious answer
is that it does not make sense, and thus does not belong in the documentation.
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Feb 2002 03:30:14
Message: <0btj7u8kr1thn1e9fppo8h3g9trsff430g@4ax.com>
On Sun, 24 Feb 2002 23:24:19 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> The obvious answer
As Chris Huff said "It would be
possible to take multiple samples per pixel, and get a smoother image...", and
I agree with him. Supersampling can take some time but use less memory in
outputed image.
ABX
Date: 25 Feb 2002 04:21:45
Message: <3c7a0229@news.povray.org>
>> The obvious answer is that it does not make sense
> As Chris Huff said "It would be possible to take multiple samples per pixel
There is a difference between "does not make sense" and "would be possible":
If you want a smooth pattern, use pattern functions and not the function
image.  If you just want a smooth "effect", set the appropriate interpolation
when using the generated image.
    Thorsten
Date: 25 Feb 2002 04:30:28
Message: <cn0k7u418hamsemt0a4r877oi7j5m8hbeb@4ax.com>
On Mon, 25 Feb 2002 10:21:42 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Right
> image.
But when calculations of this functions are very complicated and this pattern
is intersected many times (for example via reflections) then image function is
afaik only alternative to speed things up.
That's not the same, you know it.
ABX
Date: 25 Feb 2002 06:23:55
Message: <3C7A1EC4.BF8A863D@gmx.de>
> > image.
You can always generate a function image from the slow function to speed
thinks up.
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 25 Feb 2002 06:31:09
Message: <eq7k7ukc0kij83s7o7p57dvpcsmm00n5k6@4ax.com>
On Mon, 25 Feb 2002 12:23:48 +0100, Christoph Hormann <chr### [at] gmxde>
> thinks up.
That's what I said! I want this function image. But I don't want waste memory
for high resolution but imagine that there could be supersampling in
generating this image to achive smooth (not interpolated) appearance.
Note that wasn't feature request. It was just explanation that it is not non
sense to use some kind of AA in function image.
ABX
Date: 25 Feb 2002 08:30:30
Message: <3c7a3c76@news.povray.org>
  Could you tell me what is the difference between a smooth and an
interpolated image?
