POV-Ray : Newsgroups : povray.documentation.inbuilt : The docs stink. Server Time
16 Nov 2026 02:34:27 EST (-0500)
  The docs stink. (Message 1 to 14 of 14)
Subject: The docs stink.
Date: 5 Feb 2002 06:29:58
Message: <3c5fc236@news.povray.org>
No, really. They smell of limburgh.
Actually, I do have some serious comments (3.5 docs specifically, but iirc most
of these comments can be applied to 3.1 docs).
The indexing and searching can be a little counter-intuitive. For example:
Look for cylinder in the index, and "cylinder object" is returned as the second
choice. However, look for sphere, and no "sphere object" is listed. It would be
nice to be able to quickly know which listing, when multiple listings are
returned, will take you to the basic syntax for a feature (e.g. "cylinder
syntax", although "cylinder object" seems fine if it was used consistently)
Also, if you search for cylinder, "cylinder object" (the cylinder syntax) is
ranked 15, with the rather unhelpful finite solid primitives (6.5.1) returned as
rank 1. IMHO when searching for keywords, it would be better if the syntax was
always returned as rank 1.
2. I sometimes wonder if the docs would be better split into two seperate help
files - a syntax and include file help and a tutorial help. I dunno, just an
idea. I'm probably being a bit lame, but, when I need to quickly check the
syntax of an object/feature, it sometimes takes me a couple of goes, and a shift
in concentration, before I can find it in the docs.
This would also allow the tutorial help to be updated with new tutorials etc.
without having to muck around with the unchanging SDL docs.
Just my two aromas worth....
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Subject: Re: The docs stink.
Date: 5 Feb 2002 08:35:31
Message: <3c5fdfa3@news.povray.org>
In article <3c5fc236@news.povray.org> , "Tom Melly" <tom### [at] tomandlucouk>
> as rank 1. IMHO when searching for keywords, it would be better if the syntax
> was always returned as rank 1.
The "ranking" is done by the help system of your operating system, so
complaints regarding ranking problems should be directed to the the company
you got the operating system from.
    Thorsten
Date: 5 Feb 2002 08:48:13
Message: <4bov5ucqh7oa254ai8mlg9ndqmb59c5afq@4ax.com>
On Tue, 05 Feb 2002 14:35:25 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Perhaps there are some documented rules for this "ranking"? Perhaps some
additional parameter to style, tag or whatever makes more points for ranking?
Perhaps some changes invisible for reader could make this ranking more usefull ?
Was this somehow investigated ?
ABX
Date: 5 Feb 2002 09:42:29
Message: <3c5fef55$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c5fdfa3@news.povray.org...
Do you mean that the help-author gets no control over it at all?
Date: 5 Feb 2002 21:41:38
Message: <3c6097e2@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c5fc236@news.povray.org...
<snip>
Have you tried the context help (if you're using win pov)?  Hmm, I like
you're idea of two separate help files - how about a 'light' one with just
syntax, and a 'verbose' one with all the other stuff you might not
necessarily want for a quick refresh of the mind?  Of course, then new users
wouldn't want to read the complete docs, just the light one, and would get
annoyed by the docs not saying enough...
...Chambers
Date: 6 Feb 2002 04:54:42
Message: <3c60fd62$1@news.povray.org>
"Ben Chambers" <bdc### [at] yahoocom> wrote in message
news:3c6097e2@news.povray.org...
Yes - it tends to suffer from the same problem IIRC, in that it doesn't
necesserily take you to the basic syntax for the keyword.
>  Hmm, I like
Ah, those lamers will always find something to bitch about ;)
Actually, I was thinking partly of the n.users, but it's true that there is
always a downside....
Date: 8 Feb 2002 22:43:26
Message: <3c649ade@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message news:3c5fef55$1@news.povray.org...
correct (at least for windows HTML help).
Date: 9 Feb 2002 14:47:10
Message: <3c657cbe@news.povray.org>
In article <3c649ade@news.povray.org> , "Chris Cason"
On Mac OS (also using HTML based help), the author has no control either :-(
    Thorsten
e-mail: tho### [at] trfde
Date: 9 Feb 2002 18:51:15
Message: <3c65b5f3$1@news.povray.org>
    Not even by weighting the items with keywords?
Date: 11 Feb 2002 02:28:17
Message: <3c677291@news.povray.org>
for WinHelp (not HTMLHelp) you can add keywords to each topic (one page)
Date: 19 Feb 2002 23:19:58
Message: <3c7323ee@news.povray.org>
help
an
shift
Critique the following:
http://www.donovansweb.com/~chaffe/quickref.html
Robert
Date: 20 Feb 2002 11:44:27
Message: <3c73d26b$1@news.povray.org>
"Robert Chaffe" <rob### [at] earthlinknet> wrote in message
news:3c7323ee@news.povray.org...
> Robert
Wow, very nice.... any chance of a zip on the site incl. the "Notes" ?
Date: 20 Feb 2002 21:42:14
Message: <3c745e86@news.povray.org>
news:3c73d26b$1@news.povray.org...
> > Robert
Glad you like it.
I have added a link to the file qr.zip near the top of the web page.  It's
just a zip of the associated files within a single folder, so ignore any
broken links.  I'll try to remember to update the zip whenever I update the
reference.
Robert
Date: 21 Feb 2002 08:14:57
Message: <Xns91BC91437C674seed7@povray.org>
This is very nice.
Ingo
