POV-Ray : Newsgroups : povray.documentation.inbuilt : 3.7xx: max_extent (re: image resolution) is missing something? : 3.7xx: max_extent (re: image resolution) is missing something? Server Time
16 Mar 2026 11:49:56 EDT (-0400)
Date: 8 Jun 2017 13:30:00
Message: <web.593988c1122841b6883fb31c0@news.povray.org>
(running 3.7.1 beta 8)
In the in-built documentation "3.3.1.6.5 Functions"...
In the section "min_extent/max_extent', concerning the new 3.7xx feature of
reading the pixel resolution of an image, the example given there seems to be
missing something. Part of it is written like this...
#declare Resolution = max_extent ( MatteImage );
#declare MatteNormalizationScale =
There's nothing following   MatteNormalizationScale   except a semi-colon (which
naturally produces a fatal parse error, when I place an image_map pigment into
the preceeding max_extent). Should it instead be written as...
#declare MatteNormalizationScale = Resolution;
(Personally, I don't know, as I haven't tried using the feature yet.)
*However*, the remainder of that example says...
box { 0, <1,1,0.001 pigment { MatteImage }
scale MatteNormalizationScale // Fit matte to unit square
scale MatteSceneScale // Size matte for scene
....in which case,    MatteNormalizationScale = Resolution   would not seem to
make sense, as it does not "Fit matte to unit square ". (The matte image is
*already* fit to the unit square, by default.)
Some clarification(s) needed?
