POV-Ray : Newsgroups : povray.documentation.inbuilt : Finish-level Fresnel : Re: Finish-level Fresnel Server Time
22 Mar 2026 18:36:46 EDT (-0400)
Date: 21 Dec 2016 13:05:01
Message: <web.585ac3a366b60a149c5d6c810@news.povray.org>
Although the following paragraph mentions refraction, but only to say the
treatment is as though ior=1, maybe there should be at least a note about ior >1
affecting (or activating?) fresnel finish.
quote:
In the following example the diffuse, phong and specular syntax, which is
normally used to specify the effective bi-hemispheric albedo of that respective
component, does not work as advertised when finish-level fresnel is set to
non-zero. Instead, diffuse will specify the albedo that the object would exhibit
if it had a refractive index of 1, while phong and specular will specify the
albedo that the object would exhibit if it had an infinitely large refractive
index. As a result, while you would normally want to choose parameters such that
D_Value + P_Value + S_Value <= 1. With finish-level fresnel set to a non-zero
value you would want to choose parameters such that D_Value <= 1 and P_Value +
S_Value <= 1. For optimal realism, you should specify the settings as noted
below, and control the brightness of the diffuse component via the layer
pigment.
