POV-Ray : Newsgroups : povray.documentation.inbuilt : Animation docs inaccurate : Re: Animation docs inaccurate Server Time
23 Mar 2026 19:55:36 EDT (-0400)
Date: 20 Dec 2016 14:15:01
Message: <web.5859826d4da5dd729c5d6c810@news.povray.org>
> I've just noticed that the documentation of the animation settings is
> not entirely in line with the actual implementation.
> The docs claim:
> Any Final_Frame setting other than -1 will trigger POV-Ray's internal
> animation loop.
> According to the code however, animation seems to be activated whenever
> the initial and final frames are neither both equal to 0 nor both equal
> to 1.
> This discrepancy raises the question which one is correct: The code or
> the documentation?
That goes back to version 3.0 and I would guess it was meant to be a short way
of saying positive integers for final frame would activate animation.
So knowing default initial frame is 1 that meant it had to be at least 2,
obviously not 0, unless you set initial to 0 and could use final 1 instead.
