POV-Ray : Newsgroups : povray.documentation.inbuilt : Re: [solved] "mandel" as function in isosurface has unexpected results : Re: [solved] "mandel" as function in isosurface has unexpected results Server Time
13 Mar 2026 14:55:23 EDT (-0400)
Date: 16 Dec 2022 17:53:13
Message: <639cf6d9$1@news.povray.org>
On 2022-12-16 03:27 (-4), Lars Rohwedder wrote:
> https://www.povray.org/documentation/view/3.6.1/377/
> See the explanations for "interior" and "exterior" types 0 and 1.
> A default color map is not mentioned there at all, hence I did not know
> about that. :-/
>>> So I had expected that a formula like 0.9 - mandel would give the
>>> What went wrong here?
Bald Eagle wrote:
>> Part of what's going wrong is that mandel is a POV-Ray pattern that
>> has a built in color map.   And that wreaks hell with everything
>> right from the beginning.
> I see. It should be mentioned in the documentation of the mandel
> pattern. :-/
>> I'd say try using:
>> #declare Mandel = function { pigment {mandel 1000 exterior 1, 1
>> color_map {[0 rgb 0] [1 rgb 1]}}}
>> But you're having more success than I am.
> Thank you a lot! Changing the color map into a stupid black-to-white
> ramp solves the problem.
Forwarding to the documentation newsgroup.
