POV-Ray : Newsgroups : povray.documentation.inbuilt : Radiosity block `brilliance` setting : Radiosity block `brilliance` setting Server Time
8 Jun 2026 09:42:00 EDT (-0400)
Date: 16 Jun 2021 08:30:34
Message: <60c9eeea$1@news.povray.org>
Hi folks,
The following - or something along those lines - needs to be woven into
the Radiosity reference documentation on the Wiki
(http://wiki.povray.org/content/Reference:Radiosity); in addition, it
might be worth mentioning in the what's-new section:
--------------------- Syntax:
(The syntax needs to be extended to include another setting,
`brilliance`, which takes a boolean parameter, i.e. `on` or `off`.)
--------------------- Description:
By default, radiosity computations presume that the texture to render
has a `brilliance` setting of 1. In scenes that make heavy use of
radiosity, this may cause surfaces to look excessively dull.
As of POV-Ray v3.8, you can force radiosity to respect the `brilliance`
finish parameter, by specifying `brilliance on` in the radiosity block.
Note however that this comes at a cost of rendering speed, especially
when combining surfaces with various different `brilliance` settings in
close proximity.
