POV-Ray : Newsgroups : povray.documentation.inbuilt : Default values in v3.8.0 : Re: Default values in v3.8.0 Server Time
5 Apr 2026 10:59:18 EDT (-0400)
Date: 1 Oct 2018 21:44:07
Message: <5bb2cd67@news.povray.org>
Am 02.10.2018 um 00:41 schrieb Jim Holsenback:
> On 9/30/18 8:45 PM, clipka wrote:
>> "The default pigment has been {{Change}}d in version 3.8 from `rgb
>> <0,0,0>` to `rgb <1,1,1>` (requires `#version 3.8` or equivalent INI
>> setting or command-line option; see [Version Directive] for more
>> details)."
> it's been fixed in pigment and a couple of other places...look here for
> all the places i touched:
> http://wiki.povray.org/content?title=Special:RecentChanges&hidebots=0
Looks good.
Just one more thing regardig the "Version Directive" section,
specifically the portion giving example code for the version 3.8
defaults behaviour:
The revised presentation of the example code gives it the air of three
separate examples, but that's not how it was intended; rather, it was
designed as a single example, intended to demonstrate how the `#version`
directive can (or cannot) switch back and forth between defaults.
As a matter of fact, the third portion of the example wouldn't have the
described effect if used stand-alone - even if the `#default` statement
was moved from the end of the 2nd portion to the beginning of the 3rd one.
