POV-Ray : Newsgroups : povray.documentation.inbuilt : Anti-aliasing mode 3 : Re: Anti-aliasing mode 3 Server Time
22 Mar 2026 16:01:55 EDT (-0400)
Date: 23 Sep 2018 08:00:54
Message: <5ba78076$1@news.povray.org>
Am 23.09.2018 um 13:36 schrieb Jim Holsenback:
>> Sampling Methods Synopsis:
>> - Excellent! Love this mini section!
> at least it's better than the run-on sentence that used to be there
I consider it genuinely brilliant.
>> Details, Type 1:
>> - The section states that "the adaptive non-recursive method is the
>> default". I would suggest adding "if anti-aliasing is enabled" or
>> something along those lines, because the "out of the box" default is no
>> anti-aliasing at all.
> yep
Hm... the new version of the sentence seems garbled.
>> - It may or may not be worth also considering an optional alpha channel
>> in the formula given (but see further below).
> if you /really/ think it's worth it help me out a bit...i /did/ do
> something near the end of common as there was already a +ag discussion
> going on... it seemed to fit.
I think that's good enough.
>>> besides the am3 additions i also did some general cleanup and added a
>>> few visual cues to help better separate the method detail descriptions
>> Would it make sense to use sub-headings instead of just bold text?
>> Also, I guess it might be useful to add another visual cue between the
>> type 3 description and the subsequent description of common features.
> wasn't /feeling/ any of the several things i tried so i left it as is
Mind if I mess with it? Then you can blame it on me if you're still not
totally happy with it ;)
