POV-Ray : Newsgroups : povray.documentation.inbuilt : Finish-level Fresnel : Re: Finish-level Fresnel Server Time
17 Mar 2026 23:06:24 EDT (-0400)
Date: 21 Dec 2016 07:29:06
Message: <585a7592$1@news.povray.org>
Am 21.12.2016 um 12:33 schrieb Jim Holsenback:
> On 12/21/2016 3:55 AM, clipka wrote:
>> I'm changing the way the `finish` keyword will act when specified right
>> inside the `finish` block.
>> The future syntax will be as follows:
>>     FINISH:
>>       finish { [FINISH_IDENTIFIER] [FINISH_ITEMS...] }
>>     FINISH_ITEMS:
>>       ... | fresnel FLOAT | ...
>> Setting this to `on` (=1) will cause POV-Ray to realistically account
>> for the Fresnel effect in all of the following features:
>>   - ambient
>>   - diffuse
>>   - emission
>>   - phong
>>   - specular
> lol ... how am i supposed to get caught up if you keep changing/adding
Sorry. Call it necessary cleanup (adding ambient and emission to the
mix), plus a minor improvement while I was on it (making it a float
setting rather than a bool).
Smile and be glad, for things could be worse -- I'm currently already
restraining myself when it comes to entirely /new/ features ;)
(*tries to wriggle out of straightjacket*)
> testing allows:
> finish {
>   fresnel on
>   specular S_Value fresnel off
> does that mean /all/ applicable attributes get fresnel treatment
> /except/ specular
No, it means that /no/ attribute gets fresnel treatment, because the
setting /always/ applies to /all/ elements, and the later "fresnel off"
supersedes the earlier "fresnel on".
This is similar how the "metallic" setting at the finish level works:
While it is perfectly legal to write
    finish {
      phong 1 metallic on
      specular 1 metallic off
this is misleading style, since "metallic" always applies to both phong
and specular. You might just as well write
    finish {
      phong 1
      specular 1
      metallic on metallic off
with the later "metallic" statement winning over the earlier one. Which
in turn is just like
    finish {
      specular 1
      specular 0
is also perfectly legal but only the second "specular" wins.
This is a side effect of (A) allowing users to specify the finish
parameters in arbitrary order, (B) allowing users to specify a
"template" finish at the beginning of the finish block and then override
individual parameters from that template, and (C) still keeping the
parser reasonably simple (well, maybe more like "not _batshit_ crazy
convoluted").
