POV-Ray : Newsgroups : povray.documentation.inbuilt : New cone and cylinder uv_mapping added to 3.7.1 master. Add note that torus reversed in U. : Re: New cone and cylinder uv_mapping added to 3.7.1 master. Add note that t= Server Time
18 Mar 2026 17:50:33 EDT (-0400)
Date: 18 Nov 2016 07:56:26
Message: <582efa7a$1@news.povray.org>
Am 18.11.2016 um 12:20 schrieb Mr:
> William F Pokorny <ano### [at] anonymousorg> wrote:
>> 1) Cone and cylinder uv_mapping have been added to the 3.7.1 master
>> branch compliments of Jérôme. We'll need to update the supported objects
>> at:
>> http://wiki.povray.org/content/Reference:UV_Mapping
>> to reflect this. I believe the behavior is essentially like that of the
>> recently add lemon uv_mapping - but Jérôme knows best.
>> 2) We've decided to leave the uv_mapping of the torus reversed in U
>> relative to other uv_mapping given it has been this way for a long time
>> (early 2000s I think).
>> I think adding a note its mapping is reversed in U with respect to
>> others would be good.
>> Bill P.
> Does this mean the map_type 3 and 4 are in development,
> for POV-Ray, to add more basic mappings to any object even meshes and
> environment textures, like:
> FLAT map_type 0
> SPHERE map_type 1
> TUBE map_type 2?
> CYLINDER?
> CONE?
> any CUBE? or still have to use "warp { cubic }..."
Judging from your question, I presume you're not familiar with POV-Ray's
`uv_mapping` keyword.
You can think of this as a "default warp" that is different for each
primitive.
(A drawback of `uv_mapping`, is that it is only useful for surface
textures, whereas `warp` can also be used for volumetric effects.)
