POV-Ray : Newsgroups : povray.documentation.inbuilt : Lathe and Prism updates requested by Christoph. : Re: Lathe and Prism updates requested by Christoph. Server Time
5 Apr 2026 07:13:33 EDT (-0400)
Date: 27 May 2016 03:37:19
Message: <5747f92f$1@news.povray.org>
On 5/27/2016 12:07 AM, Bald Eagle wrote:
> Stephen <mca### [at] aolcom> wrote:
>> The default value is: right<1.33,0,0>. This means that the +x-direction
>> is to the right. It is called a left-handed system
> I would say that there is a definite handedness to POV-Ray, given the sign of
> different directions on the axes, and the direction of rotation around the axes
> in the (+) direction, I'd have to say that there's a default and inherent
> chirality.
I would say so too.
I know that if I use an image map and RH handiness in Bishop3D. The
image is reversed. Likewise PoseRay, on its PovRay output tab. States:
Right handed (PoseRay default) Y up
Left handed (POV-Ray default) Y up
I also used Moray where Z is up and am quite aware of all the kerfuffle
around this topic.
> Left-handed coordinate system, and "left-hand rule" for determining things like
> direction of rotation or direction of a normal.
> But that's my take as an organic chemist, casual and incidental student of
> physics and POV-Ray (l)user.
Personally I prefer the Y up because when I started work as an
Electronic Engineer, in the early 70's. The Z axis*, on an oscilloscope,
could be used to control the brightness of the waveform simulating depth.
<Aside> I seem to remember from that distant past. I was told that
engineers use the Y up, from the oscilloscope example. And that
mathematicians prefer the Z up coordinate system because they visualise
a XY graph on paper with the Z axis coming up from the desk. It doesn't
hold but it helps me visualise converting from one system to another.
* It was called the Z buffer.
# If you think I am using too many commas. It is to keep Dr. John amused. :)
Regards
