POV-Ray : Newsgroups : povray.documentation.inbuilt : Some mistake in reference 3.4.4.1.2 spotlight section : Re: Some mistake in reference 3.4.4.1.2 spotlight section Server Time
17 Mar 2026 03:26:36 EDT (-0400)
Date: 19 Nov 2013 09:18:47
Message: <528b7347$1@news.povray.org>
On 11/19/2013 09:02 AM, clipka wrote:
> Am 19.11.2013 13:52, schrieb James Holsenback:
>>> 2. The description for the forth diagram in this section "To give the
>>> tightness
>>> value full control over the spotlight's appearance use radius 0
>>> falloff 90. As
>>> you can see from the figure below." should be correct.
>>> I think that is radius 90 falloff 90 for the diagram.
>> i played around with this (quickly) and it doesn't seem to make a
>> difference if it's 0 or 90
> It does as soon as tightness comes into play.
ah ... yes i know. i guess i should have said for a given tightness both
radius values look practically the same
> There /is/ something fishy about that diagram and the paragraph before
> it. The diagram says something about "negative radius", and indeed
> doesn't match a radius of 0.
> I think in the long run the section should be overhauled, and give
> sample renders instead of (or at least in addition to) diagrams.
yeah ... there /does/ appear to be more than one rough spot, so yeah i
agree. on my todo list (sigh)
