POV-Ray : Newsgroups : povray.documentation.inbuilt : Some mistake in reference 3.4.4.1.2 spotlight section : Re: Some mistake in reference 3.4.4.1.2 spotlight section Server Time
19 Mar 2026 10:00:41 EDT (-0400)
Date: 19 Nov 2013 09:02:22
Message: <528b6f6e@news.povray.org>
Am 19.11.2013 13:52, schrieb James Holsenback:
>> 2. The description for the forth diagram in this section "To give the
>> tightness
>> value full control over the spotlight's appearance use radius 0
>> falloff 90. As
>> you can see from the figure below." should be correct.
>> I think that is radius 90 falloff 90 for the diagram.
> i played around with this (quickly) and it doesn't seem to make a
> difference if it's 0 or 90
It does as soon as tightness comes into play.
There /is/ something fishy about that diagram and the paragraph before
it. The diagram says something about "negative radius", and indeed
doesn't match a radius of 0.
I think in the long run the section should be overhauled, and give
sample renders instead of (or at least in addition to) diagrams.
