POV-Ray : Newsgroups : povray.documentation.inbuilt : File I/O Directives : Re: File I/O Directives Server Time
25 Mar 2026 10:44:54 EDT (-0400)
Date: 17 Jun 2012 04:44:11
Message: <4fdd98db$1@news.povray.org>
On 16/06/2012 9:08 PM, Chris Cason wrote:
> On 10/06/2012 03:21, Stephen wrote:
>> brings up a window with the entries; box, Cone, Interior, Isosurface,
>> Parametric&  Superquadric Ellipsoid.
> Do you mean #fopen?
out of a wet paper bag.
> (That being said, it might be useful to add 'opening files' to the
> list of index entries that are underneath 'open').
That would help people like me who only have a vague idea of the syntax.
> This and many other things should be fixed in RC6. If you would like
> to check the help file in advance (assuming you see this before we
> release), you can grab it from http://www.povray.org/temp/povray37.chm
Great! :-D
I downloaded the file and will look at it.
One thing though. When I opened the file I got a security warning saying
that it did not have a valid digital signature. I gave it permission and
when the help file opened the RH pane had the message:
   Navigation to the webpage was canceled
    What you can try:
      Retype the address.
The problem went away.
I am using Win 7
I have noticed a couple of things already, such as:
Open, prism goes to the entry above. 3.4.1.10 Parametric
Open, sor goes to 3.4.1.14 Superquadric Ellipsoid.
In fact most of the few sub entries that I have looked at go to the
entry above in the RH pane.
>> Reach for the stars goes to Duty Cycle
> That's intentional (the duty cycle feature was added for use in
> zero-gravity).
A bit Irish that. (N.B. the Mc in my surname.)
resize the help window. You lose your place in the RH pane?
Regards
