The docs show:
#declare foo2 = function {
spline {
linear_spline
0.0, <0,0,0>
0.5, <1,0,0>
1.0, <0,0,0>
#declare myvector2 = foo2(0.7);
I am testing code that has:
#declare SPL2_PX = spline{
linear_spline
#for(S_K, 0, S_NSites2D-1)
S_K, A1D_V_P2D[S_K].x,
#declare S_PX2 = function {SPL2_PX}
Parse Error: Expected 'operand', spline identifier found instead
Unless I'm doing something wrong. Which is rather often the case.
- BE
"Bald Eagle" <cre### [at] netscape net> wrote:
> The docs show:
> spline {
> linear_spline
> 0.0, <0,0,0>
> 0.5, <1,0,0>
> 1.0, <0,0,0>
> linear_spline
> #end
> - BE
I found it! The function can not use a predefined spline so if you want a
function to use a spline define the spline in the function
spline{
linear_spline
Works for me!
Have Fun!
> spline{
> linear_spline
> #end
Yes and that is indeed what I did.
However it seems to be bad behaviour by the parser, and locks the spline into a
single-use object.
IIRC, I can use pre-declared splines in sphere_sweep without a problem.
The inability falls under the "contrary to user expectation", and that's why
it's in this section.
Thank you, of course, for providing the workaround.
I wonder how many other things we have like this lurking around in the source.
- BE
hi,
> > spline{
> > linear_spline
> > #end
> single-use object.
it actually does work, though you have to tell the function:
#declare S_PX2 = function {spline{SPL2_PX}};
regards, jr.
I quickly tried one or two constructs pointed in this direction, but clearly
didn't land on that one.
Good to know for future code edits.
As always,
Thanks! :)
- bw
>> spline{
>> linear_spline
>> #end
> single-use object.
Not behaves exactly as designed: The function parser cannot handle
declared objects because you are falling into the POV-Ray declares are
not macros trap. The parser first needs to know that you want a spline
function, then it can make use of the spline object.
Thorsten
Exactly! And that is the logical way to do this, too. First tell the
parser that you actually want a spline function, then you can use a
spline. The regular syntax declares a plain function, not a spline function.
Thorsten
hi,
agree with the "consistent" point in the other post, the situation is exactly
like, say, with a 'pigment {}'.
regards, jr.
