POV-Ray : Newsgroups : povray.bugreports : hidden plane issue Server Time
6 Mar 2026 20:21:50 EST (-0500)
  hidden plane issue (Message 1 to 4 of 4)
Subject: hidden plane issue
Date: 25 Jan 2019 06:15:01
Message: <web.5c4aef64f5975424497c656a0@news.povray.org>
although hidden behind the red plane, parts of the blue plane can be seen
from the following location.
-------------- cut here ----------------------------
#version 3.7;
global_settings {
  assumed_gamma 1.0
  perspective
  location     -1 * <0, 1, 1/50000>
  direction     1 *  y
  look_at            y
light_source
    <0, -1, -1>
    color red 1.0  green 1.0  blue 1.0
plane { z, 0
  pigment{
    color rgb <1, 0, 0>
plane { z, 1
  pigment{
    color rgb <0, 0, 1>
  finish {
    ambient  1
    emission 0
The effect was discovered on Linux kernel 4.20.2 with x86_64 GNU/Linux
architecture using POV-Ray 3.7.0.8.unofficial version but can pretty much be
reproduced on any system as far as I can tell. Accept my apologies if the
issue is already known, in which case I would be grateful for any further
hints regarding a remedy.
Regards
Wolfgang
Subject: Re: hidden plane issue
Date: 25 Jan 2019 10:06:03
Message: <5c4b25db$1@news.povray.org>
Am 25.01.2019 um 12:13 schrieb gnagflow:
> Hi,
This is a simple precision issue: The camera does not "see" geometry
that is too close to the camera's location (or, more precisely, the
rays' origin). With the camera being very close to the red plane, a
circular patch of it therefore disappears.
Increase the scale of your entire scene and you should be fine.
Date: 25 Jan 2019 10:35:14
Message: <5c4b2cb2@news.povray.org>
On 1/25/19 6:13 AM, gnagflow wrote:
> Hi,
> #version 3.7;
> global_settings {
>    assumed_gamma 1.0
> camera {
>    perspective
>    direction     1 *  y
>    look_at            y
> light_source
>      <0, -1, -1>
> plane { z, 0
>    pigment{
>      color rgb <1, 0, 0>
> plane { z, 1
>    pigment{
>      color rgb <0, 0, 1>
>    finish {
>      ambient  1
>      emission 0
> Regards
> Wolfgang
Looks to be related, by magnitude, mostly to the work going on for this
pull request:
https://github.com/POV-Ray/povray/pull/358
and two or three similar open github issues - most/all? mentioned in the
358 discussion thread as I recall.
In your case the first ray surface intersection is being ignored if it
is closer than 1e-4. FYI. I'm adding your scene to my solver/tolerance
testing scene collection.
The current - and near term - work around in your scene is to keep the
camera more than 1e-4 off/outside the red plane's surface.
A better rule of thumb though is >1e-3 outside shapes / away from
surfaces for lights, cameras and surface relationships - in the world
scene space. In some scenes with the orthographic camera & user_defined
cameras that might not be possible depending upon the scene. It's not
enough for some shapes and scene set ups, but still a decent rule of
thumb value.
My current, local, solver branch going after a set of related fixes
renders only the red plane for what it's worth. That branch is an effort
aimed at fixing/improving a largish set of accuracy issues to which this
one (pull 358 et al) is somewhat related.
Bill P.
Date: 25 Jan 2019 10:45:00
Message: <web.5c4b2e7c12ed4887497c656a0@news.povray.org>
I was ray-tracing scenes close to the surface of the earth (but not too
close to be aproximated by a flat plane where curvature no longer matters).
Is there another way to increase the precision?
Thx
