POV-Ray : Newsgroups : povray.bugreports : error on plane orientation Server Time
30 Apr 2026 01:32:17 EDT (-0400)
  error on plane orientation (Message 1 to 3 of 3)
Subject: error on plane orientation
Date: 5 Jul 2010 09:25:00
Message: <web.4c31dcf856414508d66b23000@news.povray.org>
Hello,
it seems that povray does not work properly on this simple input file:
#declare s1 = sphere {<0 0 0>, 40}
#declare p1 = plane {<0 0 1>, 10}
#declare p2 = plane {<0 -0.0141 0.9999>, -10}
light_source {
 <100,-100,300>
 color White
 location <100, -100, 100>
 angle 40
 look_at  <0, 0, 0>
intersection {
 object {s1}
 object {p1}
 object {p2 inverse}
  color Blue
it should be a sphere cut by two almost parallel (xy) planes, however the second
plane (p2) is visualized as a perpendicular (xz) plane.
With:
#declare p2 = plane {<0 0 1>, -10}
everything is fine. It seems that the problem occurs when the y component of the
normal vector has negative sign. Is this a bug or there is something wrong in
this simple input file? Thanks,
 Bruno
Subject: Re: error on plane orientation
Date: 5 Jul 2010 10:40:31
Message: <4c31eedf$1@news.povray.org>
Le 05/07/2010 15:24, bruno71 nous fit lire :
> Hello,
> With:
>   Bruno
The comma are optional, but 0 -0.0141 is a valid expression for a single
number... so everything is fine, you provide only 2 components for 3D
vector, so it get extended with 0 on z (and the x part is small enough,
so the plane is oriented like +y.
Use comma in vectors.
Date: 5 Jul 2010 11:05:01
Message: <web.4c31f442e2b066b5d66b23000@news.povray.org>
> > Hello,
> > With:
> >   Bruno
Sorry, I just realized that I should post this message to povray.general before
reporting a bug. Anyway, thank you very much! I exported a geometry file from
another program (FLAIR) which is a user interface for a kind of experimental
design software, so actually there is a bug in the export function from FLAIR to
povray, and not in povray.
