POV-Ray : Newsgroups : povray.bugreports : Two BBox calculation bugs in CSG and Quadric? Server Time
11 May 2025 00:47:03 EDT (-0400)
  Two BBox calculation bugs in CSG and Quadric? (Message 1 to 10 of 10)
Subject: Two BBox calculation bugs in CSG and Quadric?
Date: 19 Aug 2019 16:28:11
Message: <rdulle5su2vkqmah9jbpmf4tvhgh81l9gp@4ax.com>
see CSG::Compute_BBox() in CSG.cpp and Quadric::Compute_BBox(Vector3d&
ClipMin, Vector3d& ClipMax) in Quadric.cpp:
            Make_BBox_from_min_max(BBox, NewMin, NewMax);
            /* Beware of bounding boxes too large. */
            if((BBox.size[X] > CRITICAL_LENGTH) ||
               (BBox.size[Y] > CRITICAL_LENGTH) ||
               (BBox.size[Z] > CRITICAL_LENGTH))
                Make_BBox(BBox, -BOUND_HUGE/2, -BOUND_HUGE/2,
-BOUND_HUGE/2, BOUND_HUGE, BOUND_HUGE, BOUND_HUGE);
CRITICAL_LENGTH is defined as 1.0e06, BOUND_HUGE/2 as 1.0e10 in both
cases.
This code will never shrink/limit the resulting BBox like the comment
above might suggest.
It will 'blow up' instead all dimensions of a BBox if just one of its
dimensions exceeds CRITICAL_LENGTH (which is still smaller than the
resulting dimension(s)).
I have no idea what the original intention might have been.
Subject: Re: Two BBox calculation bugs in CSG and Quadric?
Date: 19 Aug 2019 17:41:17
Message: <5d5b177d$1@news.povray.org>
> cases.
That bit of code came in with v3.0, but I have no idea why. I 'think' it
might be doing what's intended...
The aim isn't to shrink the bounding box, but rather to make it so
large, if already >1e6 on any side, that it is seen as an infinite
object and not included in normal bounding. BOUND_HUGE is larger than
MAX_DISTANCE (1e7). I say this without verifying that this the real
behavior though.
Bill P.
Date: 20 Aug 2019 20:33:08
Message: <243plethedulo5vg5go1otoj4vf4va5opc@4ax.com>
>> cases.
>behavior though.
>Bill P.
I don't remember anything in the code where it might help to set a big
but finite AABB to +/- infinity.
Actually this turns off BBox testing for the corresponding object.
What should be done (and is done most often) is to clip all
coordinates of a BBox to +/-BOUND_HUGE/2.
IMHO this should be done in Make_BBox(...) always, not in the caller's
code.
Date: 21 Aug 2019 06:09:48
Message: <5d5d186c$1@news.povray.org>
>> behavior though.
>> Bill P.
Yes, same here, but this looks to me to be the intent of that code.
I was thinking this too when I responded, but it's perhaps not entirely
true in 3.7 onward.
It's the case changes in 3.7/3.8 leave a last level bounding test around
the object even when bounding is off by -mb or +mb<count>. I have code
branch - now some years old - which re-enables the 3.6 and prior like
behavior of -mb. In other words, my branch really disables the inner
most bounding box test in a way similar to 3.6.
I'm wondering this morning whether that last level of bounding box test
is off for infinite objects? Though I have that patch, I just don't
remember the behavior of the code well enough to know without
investigation. If that inner most bounding test still gets done, it
might be this code hack is - in 3.7/3.8 - of no value in any case.
> code.
I agree with you and take the code to which you point to be a hack of
some sort to get around some bounding based issue. Unfortunately, there
is not a central library of test cases for past problem scenes. I don't
myself have access to the perforce code control system so don't even
know who introduced the code. We can only remove the hack and see
whether anything breaks.
I work mostly with my own version of POV-Ray. I'll put it on my list to
create a branch which removes these hacks before I build my next
personal POV-Ray version. Suppose some test cases aimed at triggering
the code hack in order too. I'm pretty certain I have nothing in my
personal test case collection which will trigger this code.
Lastly, I'd suggest we open up a github issue. Whether a bug or
intentional, seems to me the code related to CRITICAL_LENGTH should be
investigated.
Bill P.
Date: 26 Aug 2019 08:24:31
Message: <5d63cf7f$1@news.povray.org>
I've confirmed this is the behavior for the csg code with the test scene
attached to the github issue.
> true in 3.7 onward.
In some quick tests it looks like when an object is infinite it's not
tripping the bounding tests avoided by my patch branch. Given this at
least sometimes true there is some potential for this code to be fixing
or addressing some issue. In other words, see enough already to ignore
the rambling above.
> investigated.
See: https://github.com/POV-Ray/povray/issues/379
Date: 31 Aug 2019 17:09:31
Message: <i1jlmel8tnouoe3qi8p7tcugbbcm9vd86t@4ax.com>
>> true in 3.7 onward.
>the rambling above.
>> investigated.
Thanks Bill for creating the issue.
I assume it was the limited accuracy of float (used in BBox code)
which caused some problems: There are only 7 significant digits.
E.g. when you translate a BBox over a large distance it literally
loses its bits.
Also adding some +/-EPSILON to the bounds when its size is 1.0e05
already no longer works.
Generally current POV code could be improved in such situations.
E.g look at void Box::Compute_BBox(): It assigns its DBL vectors to
the float vectors of BBox without checking and might lose almost all
of its significant digits that way.
bool Inside_BBox(const Vector3d& point, const BoundingBox& bbox):
It doesn't handle the implicit +/-BOUND_HUGE means +/-Infinity at all.
The recurring recalcution of an object's BBox while parsing the scene
file makes things worse and is completely superfluous:
- do some consecutive rotations and the resulting AABB will grow each
time
- translate over some large distances and off are the bits.
An object's AABB is used in the tracing stage only, IMHO POV-Ray
should simply compose all transformations during the parsing stage and
then compute the AABB once.
This could help a lot to keep AABBs as correct and close to their
objects as possible.
Date: 2 Sep 2019 11:40:51
Message: <5d6d3803$1@news.povray.org>
> loses its bits.
Yes, thanks, conversion to float a good candidate reason for this
special treatment. Wonder why it's only applied to CSG and the quadric.
Is it because the quadric can be part of CSG and there's something about
quadric bounding making the CRITICAL_LENGTH code necessary for it alone..?
> time
While it's work that happened before I was as deep in the source code,
the bounding box code was substantially re-worked v37 to v38. A number
of issues were fixed while re-factoring the code. The work mostly, or
all, Christoph's (clipka's) I believe.
With the little I 'really' understand about the two bounding methods, I
agree, don't and I'm unsure what you mean in parts. Certainly there is
room for improvement.
My current opinion is accuracy issues due bounding follow accuracy
issues with our ray -> shape/surface solvers. Today the practical scene
limits, due ray intersection accuracy, set the working range to >1e-2 to
maybe <1e5. Though, one can do better or worse depending on many factors.
Further, numerical errors (excluding the extreme crash test kind) in
bounding are in a different numerical domain. They matter less to the
'visual' result than errors happening in the ray - surface/shape
equation normalized / somewhat-normalized domain.
Numerical error in the transforms / inverse transforms matter more, but
also not as much as the ray surface intersections to 'visual' result.
With bounding - larger is OK/safe. Missing during bounds testing of
course bad and there is a little of that going on of which we are aware
in v37 and v38. It's one of a tangle of issues part of the
https://github.com/POV-Ray/povray/pull/358 effort.
The idea of accumulating transforms before calculating the AABBs has
merit I think, though I don't see it that simply done. Usually not too
many transforms after the primitive is created we are into CSG and
optimal AABBs at that level don't, to me, look easy - excepting some
cases. Better over optimal AABBs perhaps.
Aside: We've been looking a little at bits of the bbox code due a v37 to
v38 performance degrade: https://github.com/POV-Ray/povray/issues/363.
Something for the, what that's worth, basket - maybe my understanding of
the bounding mechanism will deepen some as a result. I'll keep what
you've said in mind as I thrash around.
Bill P.
Date: 2 Sep 2019 18:35:00
Message: <web.5d6d9804c6c13c7b4eec112d0@news.povray.org>
I haven't dug down to _that_ level of the source code, so forgive me if this is
a naive question, but does POV-Ray make use of "extended precision" floats?
https://en.wikipedia.org/wiki/Extended_precision
Perhaps there's a way to track the min/max ranges and report on them in the
scene statistics?  It might help in debugging scenes, and interpreting user
feedback when there are avoidable problems simply due to scale.
Now that I have enough experience, and have asked enough newbie questions, I can
properly envision that CSG code tangle.  eek.   A naive question might be
whether or not a primitive could be internally/virtually/temporarily translated
to the origin and that "metadata" stored somehow.  Then the composed transform
matrix could be applied, and perhaps a modified ray/object intersection test
could be done in a domain where the float errors wouldn't mess everything up...
Sort of an automated version of your suggestion here:
http://news.povray.org/povray.newusers/message/%3C5bfac735%241%40news.povray.org%3E/#%3C5bfac735%241%40news.povray.org%
3E
"Today, you can 'sometimes' clean up many of the artifacts by
scaling the entire scene up (or down) by 100 or 1000x."
Date: 3 Sep 2019 08:59:45
Message: <5d6e63c1@news.povray.org>
Not in any of the mainstream versions. My solver patch branch:
   https://github.com/wfpokorny/povray/tree/fix/polynomialsolverAccuracy
supports a PRECISE_FLOAT macro mechanism for the common solver code.
It's expensive. Even long double which is on my i3 still hardware backed
was something like +150% slower IIRC. More detail on these and 128 bit
float experiments are posted about elsewhere.
My first concern with the comment to which you attached your question
isn't the potential loss of accuracy on any particular conversion given
our hard coded +-1e7 range limit, but that we are doing all these double
to single conversions which are fast opcodes, but not free.
There is a storage savings to using single floats and - in theory - a
potential to fit more single floats in any one SIMD register for
potentially faster math. However, I think due other v37/v38 code changes
the SIMD aspect mostly not happening in practice even on machine
targeted compiles. Such gains mostly don't happen with machine generic
compiles in any case.
A valid first accuracy concern - not an AABBs growing and growing by
rotations concern - I think is that we don't today accumulate as many
transforms (stored as doubles IIRC) as possible before updating the
bounding boxes, but rather - often enough - do them as they come. Each
seeing double to float conversions and potential value snapping.
Andreas's suggestion is to do the bounding box update once to a 'final'
transform and I agree this likely better.
I have thought about the parsing + bounding process creating a least
enclosing environment box which users can access. The exposure I see is
more than the final scene scale. It's that users can today use
intermediate original definitions or transformations which corrupt the
accuracy of the final rendered representation mostly without notice.
What you describe sometimes happens today and sometimes not. Numerically
for the solvers I'd like it to happen more often, but what that really
means for some shapes - sphere_sweeps for example, isn't all that clear.
Further there are other trade offs in play. On my list is a completely
different implementation for spheres using a normalized representation
so I can do some comparisons.
The new solver approach discussed elsewhere might support trade-offs
traditional solvers don't - normalization is potentially less important
numerically with the new approach. It's complicated - so much so I daily
doubt what I can really do - especially given my personal C++
impediment. Some recent ideas potentially break from recent POV-Ray code
direction too which means I'm not sure what, longer term.
> 3E
I now know the scene scaling is two edged. You can get into as many
issues scaling up as down. It just happens, I think, given the
asymmetric nature of our current practical range, and that people tend
to create data about zero, that scaling up often better centers scenes
for POV-Ray's current numerical condition.
Bill P.
Date: 5 Sep 2019 16:57:25
Message: <9mr2nepumrmdn2s125hj5dhl33rs2q4g34@4ax.com>
>> 3E
>Bill P.
I will add deferral of transformation computation and AABB calculation
next although I was doing something different right now.
I will also write down some issues with current use & intersection
calculation of AABBs.
Meanwhile here is a good read (note: really old but valid):
Search the web for "Goldberg What Every Computer Scientist Should Know
About Floating-Point Arithmetic".
The web page at oracle looked broken for me with Chrome wrt. equations
but was fine with Firefox. There are a lot of pdf versions as well.
You don't need to follow every equation, just read over them and get
an idea what can go wrong with floating-point calculations and why.
Most important are rounding errors and cancellation during subsequent
calculations with some good examples.
You'll wonder how well POV-Ray actually works :D
And we'll improve it to work even better ;)
