POV-Ray : Newsgroups : povray.bugreports : makemesh problem Server Time
11 May 2025 04:24:09 EDT (-0400)
  makemesh problem (Message 1 to 5 of 5)
Subject: makemesh problem
Date: 1 Jul 2024 06:12:42
Message: <6682811a@news.povray.org>
"makemesh.inc" by Ingo Janssen in 2002 is a superb and very useful macro.
But I found a small issue. For "small" resolutions, it's okay.
At higher resolutions, however, the bug appears.
Let's say the resolution is 1000.
So we have Iter_U = 1000 and Iter_V = 1000
When using the generated file created by "makemesh.inc"
i get this error :
"10_sphere_mesh.txt"
line 200404
Parse Error: No matching }, < found instead
By studying what the file (122Mo) contains i can see :
#declare Surface = mesh2 {
  vertex_vectors {
    1.002e+06
  normal_vectors {
    1.002e+06
  uv_vectors {
    1.002e+06
  face_indices {
    2e+06
As you can see, the number of elements in each section is in scientific
notation.
But, 1.002e+06 is interpreted as 1 002 000 while the real number is 1
002 001.
Of course the POVRay finds vector's elements before the end of section.
The lines in question look like this :
#write(
	FILE_HANDLE,
	"  vertex_vectors {\n",
	"    ", NumVertices,"\n    "
Just change :
By :
	"    ", str(NumVertices,0,0),"\n    "
And it works like a charm!
The official distribution of this macro should be corrected, but I don't
know where it is.
Ingo Janssen doesn't seem to have a site anymore.
Hope that help ;)
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: makemesh problem
Date: 1 Jul 2024 07:05:00
Message: <web.66828d27cf5155ee1f9dae3025979125@news.povray.org>
kurtz le pirate <kur### [at] gmailcom> wrote:
> Just change :
> By :
Nice catch, and excellent debugging!
> know where it is.
https://ingoogni.nl/
- BW
Date: 1 Jul 2024 09:00:00
Message: <web.6682a76acf5155ee17bac71e8ffb8ce3@news.povray.org>
Thanks, I'll have a look and report back when fixed with proper link etc.
ingo
> know where it is.
Date: 1 Jul 2024 10:50:00
Message: <web.6682c207cf5155ee17bac71e8ffb8ce3@news.povray.org>
Bonjour Kurtz
What version, are you using? The one on my site seems to run fine and searching
for ' NumVertices,"\n ' yields no result. The same for the files in the POV-Ray
distributions. Could you test with the include file from :
https://ingoogni.nl/download/MMM.zip
ingo
Date: 1 Jul 2024 13:37:15
Message: <6682e94b$1@news.povray.org>
> Bonjour Kurtz
Bonjour Ingo,
The version i use :
// Persistence of Vision Ray Tracer Include File
// File: makemesh.inc
// Vers: 3.5
// Desc: Macros and functions used in builing mesh2 objects.
// Date: 2002/04/27
// Auth: Ingo Janssen
The test with makemesh in "MMM.zip"
// Vers: 3.5
// Date: 2002/04/27
// Rev 2002/10/23 : Added the CheckFileName macro.
//                  Added the option to write Wavefront *.obj files.
//                  Added the option to write *.pcm files, for Chris
Colefax' Compressed Mesh Macros.
//                  Added the option to write *.arr files, this writes
only the arrays to a file.
// Rev 2004/26/5 :  Changed the order the vertices are written in to
counter clockwise
And your site say : "Last update: 2019-01-04" for makemesh.
... I use the original version of April 27, **2002**
I'm "really" not up to date !
Thanks for your answer, all is ok.
Kurtz le pirate
