POV-Ray : Newsgroups : povray.bugreports : crand is not thread safe in any >=3.7 version. Do we care? Server Time
18 Mar 2026 05:08:43 EDT (-0400)
  crand is not thread safe in any >=3.7 version. Do we care? (Message 1 to 7 of 7)
Subject: crand is not thread safe in any >=3.7 version. Do we care?
Date: 6 Mar 2018 06:44:59
Message: <5a9e7f3b$1@news.povray.org>
While continuing to play with media and fog, I stumbled across the fact
the crand mechanism is not thread safe in a render block, blotchy way.
Do we care enough about this feature to open up a github issue?
It's not on my list of used features. However, it's used in our mist.pov
sample scene, for example, which forces +wt1 when the scene is included
in any image comparison testing.
Updating our sample scenes (7 by my count) to not use crand OK with me
too, but ?
Bill P.
Subject: Re: crand is not thread safe in any >=3.7 version. Do we care?
Date: 7 Mar 2018 08:23:58
Message: <5a9fe7ee$1@news.povray.org>
> too, but ?
> Bill P.
No opinions eh? ;-)
Took a few minutes to search back through the newsgroups and it looks
like this feature was out of 3.7 development for a time and then
restored with some asking for it in 3.7.
When I get a moment I'll either open up a github issue or a pull request
if a quick look at the code shows an easy fix like c++11's thread_local.
Bill P.
Date: 7 Mar 2018 09:18:48
Message: <5a9ff4c8$1@news.povray.org>
Perhaps best I talk to myself... Turns out there is a separate random
number generator set up for crand - suppose for speed reasons and that
the set up intentional. Going to walk away.
Use +wt1 if using crand and you want 'frame/view' renders to be the same
render to render.
Bill P.
Date: 7 Mar 2018 10:47:06
Message: <5aa0097a$1@news.povray.org>
Am 07.03.2018 um 15:18 schrieb William F Pokorny:
>> request if a quick look at the code shows an easy fix like c++11's
>> thread_local.
> render to render.
> Bill P.
Maybe we can concoct something that will keep the crand stable when
using the "+HR" option. While currently only having an effect on
radiosity, the intention of the switch was to also change the behaviour
of any other stuff that's affected by thread assignment and render block
ordering.
My suggestion would be to re-seed the crand noise generator each time a
new block is started, maybe using a seed based on the block number in
order to prevent visible repetitions.
Subject: Re: crand is not thread safe in any >=3D3.7 version. Do we care?
Date: 7 Mar 2018 18:05:00
Message: <web.5aa06efc7e4b5b1fa47873e10@news.povray.org>
(in 3.7.1 beta 9, running 2 threads-- as far as I can tell with my processor.)
I don't know if this helps:
I ran a simple 15-frame animation, of crand on a box. 800 X 600,
Render_Block_Size 80 (so that's 10 blocks across and 7.5 blocks down) Then used
frame 1 as a reference to 'difference' the others from it in Photoshop.
What I see is random blocks being identical from frame to frame, at random
locations. Sometimes only a few blocks, sometimes many. And the individual
frames have some random repeated blocks as well, which change from frame to
frame too.
(BTW, I'm thinking that these results may have some bearing on Bill's earlier
thread about SSLT and its own repeating 'block' behavior. Or maybe not.)
One other note: For crand to show up on an object, the object needs at least
*some* finish{diffuse...} amount. Full ambient or emission by itself doesn't
show it. I didn't know this until now.
#version 3.71;
global_settings {assumed_gamma 1.0}
  orthographic
  location  <.5, .5, -10>
  look_at   <.5, .5,  0>
  angle 20
light_source {
  0*x                  // light's position (translated below)
  color rgb <1,1,1>    // light's color
  translate <20, 40, -20>
plane{z,.1
    pigment{rgb 1}
    finish{ambient 0 emission 0 diffuse 1 crand 1.0}
Date: 8 Mar 2018 08:18:08
Message: <5aa13810$1@news.povray.org>
>> render to render.
> ordering.
Thanks.
I think using "+HR" here a good idea. Your approach though looks low
cost cpu wise to me though a more complicated implementation. Maybe fast
enough the more stable way is how crand could work all the time...
I'll open up a github issue including a pointer back to this thread when
I get the chance.
Bill P.
Date: 4 Apr 2018 08:57:12
Message: <5ac4cba8$1@news.povray.org>
> I get the chance.
See:
https://github.com/POV-Ray/povray/issues/353
Bill P.
