POV-Ray : Newsgroups : povray.bugreports : CLipka: Possible BUG Found!!! :-) Server Time
8 Oct 2026 17:39:47 EDT (-0400)
  CLipka: Possible BUG Found!!! :-) (Message 1 to 22 of 22)
Subject: CLipka: Possible BUG Found!!! :-)
Date: 12 Feb 2016 04:36:27
Message: <56bda79b$1@news.povray.org>
Yip,
and once again I gladly report a possible BUG! At least, it seems to be
a bug, let's see.
The following code causes no problem:
object
 HF_Cylinder( Fn_1, // Function,
                 0, // UseUVheight:  0 or 1
                 1, // UseUVtexture: 0 or 1
           <50,50>, // Resolution,
                 1, // Smooth: 0 or 1
                "", // FileName, ""=no file,
           <0,0,0>, // EndA,
         <0,1.5,0>, // EndB
              1.60 ,// Radius
               0.05  // Depth
 scale < 0.58, 0.67, 0.58 >
 rotate < 90.0, 0.0, 0.0 >
 scale < 1500.0, 1500.0, 2500.0 >
But using now a heightfield, I get an error message.
object
 "Colony Ship I - Heightfield Landscape.png", // FileName, ""=no file,
           <0,0,0>, // EndA,
         <0,1.5,0>, // EndB
              1.60 ,// Radius
               0.05  // Depth
 scale < 0.58, 0.67, 0.58 >  // error here when using a heightfield
The error message is:
"Parse Error: Expected 'object', scale found instead"
PITA nomination?   :-)
Subject: Re: CLipka: Possible BUG Found!!! :-)
Date: 12 Feb 2016 14:41:47
Message: <56be357b$1@news.povray.org>
Am 12.02.2016 um 10:35 schrieb Sven Littkowski:
> a bug, let's see.
Guess what: Again it isn't :P
> object
>            <0,0,0>, // EndA,
>          <0,1.5,0>, // EndB
>               1.60 ,// Radius
>                0.05  // Depth
You've misunderstood the FileName parameter.
From the documentation:
There are several HF macros in shapes.inc, which generate meshes in
various shapes. All the HF macros have these things in common:
* The HF macros do NOT DIRECTLY USE AN IMAGE for input, but evaluate a
user-defined function. The macros deform the surface based on the
function values.
* The macros can either WRITE TO A FILE to be included later, or create
an object directly. If you want to output to a file, simply specify a
filename. If you want to create an object directly, specify "" as the
file name (an empty string).
Specifying a FileName would be useful in animations, or if your
(pseudo-) height field is so large that you don't want it to be
re-computed each time you render the scene, e.g.:
    #declare RecomputeHFCylinder = (clock = 0);
    #if (RecomputeHFCylinder)
      HF_Cylinder( ..., "Foo.inc", ...)
    object {
      #include "Foo.inc"
      scale ...
Note that when used in this mode, the HF_Cylinder(...) macro does not
evaluate to an object, but simply generates the specified file as a side
effect, so your code
    object {
      HF_Cylinder( ..., "Heightfield Landscape.png", ...)
      scale ...
will evaluate to
    object {
      scale ...
while at the same time overwriting(!) the file "Heightfield
Landscape.png" with plain text reading:
    mesh2 {...}
To generate a HF_Cylinder from an image, you'd need to use a pigment
function.
Absolutely ;)
Date: 12 Feb 2016 15:02:33
Message: <56be3a59$1@news.povray.org>
Not a bug? Damn.
Ah. Forget the PITA nomination for a moment. Yeah, put it aside.
I think, I really want to go ahead with your suggestion, to create a
twisted heightfield from an image. I will continue inside the GENERAL
section.
Date: 12 Feb 2016 19:04:33
Message: <56be7311$1@news.povray.org>
On 2/12/2016 3:01 PM, Sven Littkowski wrote:
> Not a bug? Damn.
I think it qualifies for double secret pita.
Date: 12 Feb 2016 20:53:07
Message: <56be8c83$1@news.povray.org>
He he he!
Date: 13 Feb 2016 00:20:01
Message: <web.56beba7f56d165d233c457550@news.povray.org>
The HF_Cylinder macro can be a bit daunting to work with when it uses an
image_map as a function. I re-worked your code, to give you a good introduction
to it. (Also take a look at 'Function Image' in the documentation.)
For everything to work correctly, start with a 'standard' cylinder size (1.0
length, with radius .5, not 1.0). To have the proper 'equalized' x and y
triangle resolutions in the heightfield (no squashing or stretching of
triangles), the macro's x-resolution needs to be int(pi)*res, not just res. You
can see what I mean by reducing the resolution to 10,10, to see the triangle
shapes.
To reproduce your image_map correctly on the cylinder, the image itself needs to
have a width-to-height ratio of pi:1.0 (using the appropriate image resolution
that you want, of course.)
--- code ---
#declare Fn_1 =
function{
 pigment{
  image_map{jpeg "your_image.jpg" once interpolate 2}
  // this image needs to be pi-units wide by 1.0 tall, NOT square.
// You can use these two modifiers to 'reverse' the imagery, to see it
// correctly on the INSIDE. HOWEVER, this does not reverse the *depth* of
// the heightfield. The only way to do that (that I know of) is to invert
// the image_map's colors (in Photoshop, for example.)
                //scale <-1,1,1>
                //translate <1,0,0>
object{
 HF_Cylinder( function{Fn_1(x,y*1.7,z).gray}, // *Needs* the function 'wrapper'
                 1, // UseUVheight:  0 or 1 // ON-- IMPORTANT
                 0, // UseUVtexture: 0 or 1
 <int(100*pi),100>, // Resolution.
           <0,0,0>, // EndA,
         <0,1.7,0>, // EndB-- if this y-value is different from 1.0,
                    // change the function's y-value above to compensate.
                .5, // Radius. Keep this at .5 for 1:1 reproduction of
                    // the image_map around the circumference.
                0.3 // Depth
Unlike a regular height_field, the image_map eats INTO the cylinder (but with
the correct 'positive' grayscale height values.) For example, if your image_map
has white values that are 1.0 in brightness, that part of the corresponding
cylindrical heightfield will by at the outer radius of the cylinder surface;
darker image colors will eat *into* the cylinder.
The HF_Cylinder macro reproduces the image_map correctly on the OUTSIDE, not the
inside. To get it to look correct on the INSIDE instead, you can 'flip' the
image left-to-right in the image_map's code as I've mentioned, OR by making the
x-value in function(x,y,z) into (-x + 1). This along with a color-INVERTED
image_map will give you the correct heightfield INSIDE the cylinder.
If you want to MAKE the cylinder taller than 1.0 (EndB above), you need to
compensate for that by increasing the triangle Y-resolution.
Have fun experimenting!
Date: 13 Feb 2016 05:10:07
Message: <56bf00ff$1@news.povray.org>
Hi, big thanks. To be honest, I couldn't have worked out these
mathematics just by myself. Especially the requirements on the image.
If I understand correctly, the side ratio of the image has to be 3.14 x
1.0, correct? If I have an image 10,000 pixels high, the width needs to
be 31,400 pixels.
Well, this is exciting. I am making a test right now.
Date: 13 Feb 2016 11:25:01
Message: <web.56bf563956d165d233c457550@news.povray.org>
> be 31,400 pixels.
Yes. But you don't need to be 'locked in' to that ratio. Once you understand the
HF_Cylinder behavior better, you can change that. For example, in the code I
posted, I deliberately made the cylinder 1.7-units high (not 1.0) while also
using a 'standard' pi:1-ratio image-- to show how you can get the 'image
function' to still look correct on the heightfield. But if you really want a
taller cylinder than 1.0, the original image_map should be *created* taller as
well-- then you would likewise change the scale somewhere in the HF_Cylinder to
make sure everything looks correct.
By the way, if you want to apply the same image_map as a PIGMENT to your
heightfield, turn on 'UseUVtexture' in the macro. To save on memory and parse
time, pre-#declare the image_map like this...
#declare CYL_PIGMENT =
     pigment{
           image_map{jpeg "my_image.jpg"  once interpolate 2}
Then you can use it as your HF function...
#declare Fn_1 =
function{
 pigment{
  CYL_PIGMENT
  //scale <-1,1,1>
  //translate <1,0,0>
..... and also in your texture definition.
An interesting fact: When using the 'once' keyword in the image_map, AND also
applying it as a texture/pigment, the HF_Cylinder only shows up where the
pigment is applied-- any remaining part of the cylinder disappears. It's as if
the other parts of the cylinder have a totally transparent texture on them (even
though the original image has no alpha-channel.)
By the way: In my code example, I wrote this code line...
If you haven't worked with functions before, what that *really* means is
                          <x,y/1.7,z>
Multiplication and division are written the *opposite way* in functions (or
'inverse' way) of what you would normally write.
Date: 13 Feb 2016 15:41:59
Message: <56bf9517$1@news.povray.org>
Yes, and that is, where my own boundaries begin: functions. That is a
field, in which I was never good (though I am excellent in some other
fields)...
But yes, I understand, that for a cylinder I have to work with 3.14, due
to its shape.
Once I manage to have the heightfield in the cylinder, I will work then
on a texture, and then on plants and finally on buildings.
>> be 31,400 pixels.
>      pigment{
> #declare Fn_1 =
> function{
>  pigment{
>   CYL_PIGMENT
>   //scale <-1,1,1>
>   //translate <1,0,0>
>                           <x,y/1.7,z>
Date: 13 Feb 2016 23:01:50
Message: <56bffc2e@news.povray.org>
Kenneth,
using your code, I am able to project the image into the shape of a
cylinder. But I cannot put my green pigment on it, it remains in its
gray colors (like the original image). How to change that?
I have the thread "The Colony Ship" inside the "Images" section here,
and could upload the images there. But here is the code:
#declare Fn_1 = function
 pigment
  image_map { jpeg "Colony Ship I - Heightfield Landscape.jpg" once
interpolate 2 }
                //scale <-1,1,1>
                //translate <1,0,0>
#declare TheLandscape = object
 HF_Cylinder(function { Fn_1(x,y*1.7,z).gray }, // *Needs* the function
'wrapper'
// ON-- IMPORTANT
                                       <0,0,0>, // EndA,
                                           0.5, // Radius. Keep this at
the circumference.
                                            0.3 // Depth
#declare MyLandscape = union
 object { TheLandscape scale < 1.0, 1.0,  1.0 > translate < 0.0, 0.0,
0000.0 > }
 object { TheLandscape scale < 1.0, 1.0, -1.0 > translate < 0.0, 0.0,
5000.0 > }
 pigment { rgb < 0.05, 0.25, 0.0 > }
 finish { emission 0.0 }
>>      pigment{
>> #declare Fn_1 =
>> function{
>>  pigment{
>>   CYL_PIGMENT
>>   //scale <-1,1,1>
>>   //translate <1,0,0>
>>                           <x,y/1.7,z>
Date: 14 Feb 2016 04:20:00
Message: <web.56c045b056d165d233c457550@news.povray.org>
> Kenneth,
That's odd. I DO see the green color, using just your code example. Did you
combine the 'MyLandscape' object with some other CSG and then apply another
different 'gray' texture?
Yes, post an image there.
Date: 14 Feb 2016 15:05:00
Message: <web.56c0dd1f56d165d233c457550@news.povray.org>
Actually, that's only half-true (which has just become clear to me-- and I've
been working with the HF_Cylinder macro for years!)
As the 'depth' value in the macro increases, the radius of the entire
height_field cylinder ALSO increases (but not the *length* of the cylinder)--
you end up with a 'fatter' cylinder, which actually distorts the 3D image_map
pattern. The pattern looks stretched-out horizontally. (You can see this by
setting 'depth' to an extreme .99.)
IDEALLY, as 'depth' increases, the cylinder should stay at the same radius, with
the image_map function simply 'eating into' it. But that's not what happens.
I'm working on some SCALE equations to compensate for this, but it's...
complicated. The first thing to do is to scale up the *length* of the cylinder,
to get the embossed pattern to look undistorted again. Then the entire cylinder
needs to be scaled *down*, to get it back to its original radius and length.
The tricky thing about this is that it all depends on the particular 'depth'
value used.
Date: 14 Feb 2016 15:28:37
Message: <56c0e375$1@news.povray.org>
Am 14.02.2016 um 21:01 schrieb Kenneth:
That wouldn't be ideal either, as it would /reduce/ the effective radius
of the entire height_field cylinder on average, creating the opposite
distorting effect.
The fact is that there is no ideal solution (because there is no telling
what the average height of your image_map function is), and whoever
implemented HF_Cylinder just picked this particular implementation for
other properties.
The primary reason may have been that a corresponding behaviour in
HF_Sphere makes it easy to use for modeling planets, with the nominal
radius specifying sea level and everything else being raised above it.
> value used.
Maybe the easiest way to approach this is to simply adjust the nominal
radius parameter as you change the depth parameter.
Date: 14 Feb 2016 16:45:01
Message: <web.56c0f47956d165d233c457550@news.povray.org>
> > with the image_map function simply 'eating into' it. But that's not what
> > happens.
> distorting effect.
I was assuming (probably incorrectly) that the image_map itself would always
have *some* pure white areas in it-- which would equate to the max height of the
HF (meaning, the max radius of the HF_Cylinder.) It's that max radius I was
referring to. In experiments I'm doing with two really odd (and dynamic) scaling
equations, I can *almost* get that max radius AND height to stay at set values,
no matter what the 'depth' value. But "almost" isn't quite good enough yet...
Date: 15 Feb 2016 06:20:17
Message: <56c1b471@news.povray.org>
Seeing all these problems, I am wondering, if there is a possibility in
POV-Ray, to twist a given OBJECT to become a cylinder.
If that function does not exist yet, here is a suggestion:
1
That function needs to twist an object of any dimension, example:
that object is not 1 unit tall, but lets say 10 units (imagine a box)
2
When twisting to a cylinder, there is no standard size (of 1 unit), but
the radius is set by the user, this way, a cylinder-twisted object with
a height of 10 units would not lead to a cylinder that is fully filled,
if the cylinder radius was set to let's say 100 units. Also, the user
can set the begin and end radius, that enables cylinders and also funnels.
Here my vision:
The object ("MyObject) must be centered by the user at < 0, 0, 0 > and
the lowest point (Z axis) must be 0, while the highest point is open
(any number). The user cares about that by using the proper radius. The
OBJ_Cylinder function creates a cylinder from let's say -X to +X, the
radius from -Z to +Z.
Here, MyObject is assumed to range
from <-10.0, 0.0, -5.0> to <10.0, 10.0, 5.0>
 OBJ_Cylinder(object { MyObject }, // the object to be twisted
                             10.0, // X (X Expanse of object)
                              5.0, // Z (Z Expanse)
                            100.0, // Cylinder Radius Begin
                             90.0, // Cylinder Radius End
 rotate < 90.0, 0.0, 0.0 >  // any common object modifiers)
>>> happens.
>> distorting effect.
Date: 15 Feb 2016 11:32:16
Message: <56c1fd90$1@news.povray.org>
> 1
> 2
> Here my vision:
>>>> happens.
>>> distorting effect.
Maybe this will help.
http://www.reocities.com/SiliconValley/Lakes/1434/bend.html
I've never used it.
Mike
Date: 15 Feb 2016 13:54:26
Message: <56c21ee2$1@news.povray.org>
Am 15.02.2016 um 12:20 schrieb Sven Littkowski:
Nope. Not with arbitrary objects.
Forget it. With most shapes, you'd need to convert them to something
more generic first, meshes being the most obvious choice.
Date: 15 Feb 2016 17:30:43
Message: <56c25193$1@news.povray.org>
> I've never used it.
> Mike
Are these links all written down anywhere (like in the wiki)? Or is it
just individual bookmarks.
Years ago, someone had a blob tutorial (Jaime or Warp?) that I'd like to
find.
dik
Date: 15 Feb 2016 22:07:03
Message: <56c29257@news.povray.org>
I saw it, just recently. The URL was given to me inside one of my
threads here, where I asked about water media.
> find.
Date: 15 Feb 2016 22:08:38
Message: <56c292b6$1@news.povray.org>
Somewhere inside my "Wanted: Air and Water" thread, inside the GENERAL
section of this newsgroup.
> find.
Date: 15 Feb 2016 22:10:40
Message: <56c29330$1@news.povray.org>
Here it is, I found it:
http://runevision.com/3d/
> find.
Date: 15 Feb 2016 22:29:48
Message: <56c297ac$1@news.povray.org>
>> I've never used it.
>> Mike
> find.
> dik
I just happened to remember it.
Mike
