POV-Ray : Newsgroups : povray.bugreports : TIF support broken? Server Time
14 Jul 2026 14:35:23 EDT (-0400)
  TIF support broken? (Message 1 to 10 of 14)
Subject: TIF support broken?
Date: 9 Sep 2009 13:21:19
Message: <4aa7e40f$1@news.povray.org>
It appears to me that TIFF file input is broken, leading to a
transparent texture when used in an image_map; can someone confirm?
Subject: Re: TIF support broken?
Date: 9 Sep 2009 13:25:51
Message: <4aa7e51f@news.povray.org>
I should have mentioned that this is about 3.7 (beta.34 to be exact).
Date: 9 Sep 2009 14:58:53
Message: <4aa7faed$1@news.povray.org>
Apparently, the behavior is different for compressed and uncompressed files.
Date: 9 Sep 2009 15:18:57
Message: <4aa7ffa1$1@news.povray.org>
> files.
... and POV-Ray 3.6.2 renders both properly; I presume that this is an
issue in the TIFF library: In the POV-Ray 3.6.2 branch, it has been
updated to libtiff 3.8.2, while POV-Ray 3.7 still uses libtiff 3.6.1.
I tried to "transplant" the libtiff 3.8.2 from POV 3.6.2 over to the
POV-Ray 3.7 project, but with not much success yet.
Date: 9 Sep 2009 18:30:14
Message: <4aa82c76$1@news.povray.org>
>> files.
POV-Ray supports only a (particular small) subset of possible
TIF-formats and IIRC there was a change between libtif 3.6 and 3.8
regarding alpha channels and the recommended way the tag
'TIFFTAG_EXTRASAMPLES' should be interpreted.
POV-Ray also ignores all colorimetric and gamma correction related tags.
And POV-Ray does not support all the 'interesting' TIF-formats like
16bps, 24bps, and 32bps floating point HDR anyway.
In fact TIFF support is 'broken' in so many ways that I would drop it
completely. I can estimate how much time is needed to write some
reliable TIF importer and I think this time would be better spend for
the more important things within POV-Ray.
-Ive
Date: 10 Sep 2009 01:28:06
Message: <4aa88e66$1@news.povray.org>
That must then be why POV-Ray 3.6.2 handles those TIFF files properly
while 3.7 does not.
I think retaining support for the most basic TIFF files won't hurt, and
in that case it would appear rather odd for POV-Ray 3.7 to support less
variants of TIFF than 3.6.2.
Anyway, I got the libtiff 3.8.2 running with POV-Ray 3.7 now, and will
submit the changes to the repository any minute.
Date: 10 Sep 2009 04:25:51
Message: <4aa8b80f$1@news.povray.org>
It seems POV-Ray does not even support the 'most basic' TIF-files.
POV-Ray uses the so called RGBA-libtif interface and this interface
returns *always* 8 bit/sample 32 bit/pixel data. A simple uncompressed
16bps grayscale image (e.g. for hight fields) will be used by POV-Ray
reduced to 8bps but stored as RGB+A. So in this case we have a loss of
information (16 -> 8 bit) together with a waste of memory.
POV-Ray throws a warning about this 16bit->8bit conversion, but only if
the input *is* exactly 16bit but other bit-depth are quite common within
TIFF. Therefor at least the line
if (BitsPerSample == 16)
BytesPerSample = 2;
options.warnings.push_back
("Warning: reading 16 bits/sample TIFF file; components crunched to 8");
within tiff.cpp should be changed to
if (BitsPerSample > 8)
But even then e.g. Greg Ward's LogLuv HDR TIFF files will be *silently*
converted and used by POV-Ray as simple LDR 8bps data. No warning, no
message and no documentation about this behavior. This is definitely not
the way image import should be handled.
Also the input for 'simple' color palette TIFF is broken as it does
ignore the possibility of tiles instead of strips within TIFF. And this
causes even a segfault!
To avoid the possible crash the line
if (PhotometricInterpretation == PHOTOMETRIC_PALETTE)
if ((PhotometricInterpretation == PHOTOMETRIC_PALETTE) &&
(TIFFIsTiled(tif) == 0))
The latest libtif release is 3.9.1 and fixes numerous bugs (including
some fixes provided by me ;) compared to 3.8.2.
-Ive
Date: 10 Sep 2009 06:12:26
Message: <4aa8d10a$1@news.povray.org>
Well, it does /support/ them in the sense that you can use them. Whether
it supports them /well/ is a perfectly different thing.
> [... lots of chode change suggestions...]
You mind adding one (or separate) tasks into the bugtracking system for
this (http://bugs.povray.org/), so these might be followed-up as time
permits?
That may well be, but 3.8.2 is the one working successfully in POV-Ray
3.6.2 for Windows, so I figured it would be easiest to get it to compile
with 3.7 as well :-)
You're welcome of course to go for integrating 3.9.1 into POV-Ray,
including Visual Studio 8 and 9 projects and all...
Date: 10 Sep 2009 12:44:35
Message: <4aa92cf3$1@news.povray.org>
If you indeed see it that way so why did you bother about the alpha
channel? You could *use* it, couldn't you even if not as you did expect
but citing you this is a perfectly different thing.
And changing from libtif 3.6 to 3.8 (or 3.9) does not fix anything
regarding the possible pre-multiplied data for TIF-files using an alpha
channel, it only will make support for the other 50% of files that *did*
previously work broken!
If somebody notes e.g. that POV-Ray does claim to support TIFF and his
intention is to quickly visualize a 32-bit-signed-integer GEO-TIFF
height-field all he will get from POV-Ray is an output where the
negative values are clipped to zero and the height-field uses only 8
bit data (as delivered by the libtif-RGBA-interface currently used by
POV) instead if at least 16bit. But POV-Ray will give him no warning
about this and it is nowhere documented. This person will therefor
decide that POV-Ray is just a crappy renderer and he will not know and
care that only the POV-Ray TIFF support is *just* not very well.
And this is nothing I imagined, this is a real world example.
> permits?
After giving it some thought, no I wont, because I do not even know
where to begin. From my own 'simple' tiff-test-suit POV-Ray reads only
about 20% as expected and a good deal of the other 80% causes even a
segfault. And I mean 'simple' because I have also an 'advanced' image
set where more of the uncommon TIFF-images are collected.
-Ive
Date: 10 Sep 2009 16:07:51
Message: <4aa95c97@news.povray.org>
Ive schrieb:
>> Whether it supports them /well/ is a perfectly different thing.
Well, I think there is a difference here: What I was talking about was
loss of quality. What you're referring to is inability to see the image
at all. Which is a much more "WTF"-ish situation than distorted colors:
Where's my object? Did I break the geometry? Do I have scaled up the
scene too much? I guess broken input file handling is the thing that
comes to mind last in such a situation. Whereas if the colors look
crappy, it's easier to notice that something might be wrong with the
image file.
I know not much about that; if you know a better solution to get even
the most dumb-ass photoshopped TIFF files to show, you're welcome to
join the ranks and get your hands dirty on the code. But since POV-Ray
3.6.2 has gone that road for libtiff 3.8.2, and has done so with some
success (after all, it does properly read the very vanilla
8-bit-per-color non-transparent TIFFs a most-stupid-of-all-users is most
likely to produce, which POV-Ray 3.7 using lbtiff 3.6.1 failed at), it's
also a matter of consistency to pull 3.7 in that direction as well.
Besides, if a user is proficient enough to use highly sophisticated
variants of TIFF, chances are he knows a bit more about the pitfalls and
typical incompatibilities associated with their use than a dumb-ass
photoshopping noob.
Ah, and did I mention that one of the TIFFs POV-Ray 3.7, using libtiff
3.6.1, failed to load was created by IC with the very default settings?
So if the problem wasn't in libtiff but in TIFF files not conforming to
specifications, wouldn't that mean that IC is buggy?
"Parse Warning: This rendering uses the following experimental
feature(s): TIFF image support. The design and implementation of these
features is likely to change in future versions of POV-Ray. Full
backward compatibility with the current implementation is NOT guaranteed."
Even though it doesn't *explicitly* say that support is far from
perfect, I think it should be clear enough. "Experimental" is the
keyword here.
>> for this (http://bugs.povray.org/), so these might be followed-up as
>> time permits?
Well, in that case I consider it a bit moot to complain. The problems
will not solve themselves, nor will anyone of the dev team or the other
code contributors solve them unless they know about them in the first place.
