POV-Ray : Newsgroups : povray.bugreports : POV-ray should use multiple threads Server Time
7 Mar 2026 08:31:55 EST (-0500)
  POV-ray should use multiple threads (Message 1 to 5 of 5)
Subject: POV-ray should use multiple threads
Date: 12 Aug 2009 15:25:27
Message: <4a831727@news.povray.org>
Ray-tracing is trivially parallelisable. Keeping to a single thread even
on multiple-CPU machines is kind of weird.
POV-ray should try to detect the number of CPUs, or if it can't, let the
user enter the number of threads POV-ray should spawn.
POV-ray should then split the workload of rendering the image into that
number of threads.
Suggested algorithm (pseudo-code):
Let n = number of CPUs (or configured number of threads).
Let h = height of the output bitmap.
Let lines = list of integers initialised to [0, 1, 2, ..., h-1].
Spawn n threads, where each thread does the following:
   Obtain a mutex on 'lines'.
   If 'lines' is empty, release the mutex and return.
   Remove an integer y from 'lines'.
   Release the mutex on 'lines'.
   Render the row of pixels at y co-ordinate 'y'.
   Go back to start.
Wait for all n threads to complete.
Done.
Timwi
Subject: Re: POV-ray should use multiple threads
Date: 12 Aug 2009 17:07:34
Message: <4a832f16@news.povray.org>
  A much easier algorithm: Write the following in the address bar of your
web browser: http://povray.org/beta/
Date: 12 Aug 2009 19:15:10
Message: <4a834cfe$1@news.povray.org>
>   Go back to start.
> Done.
Congratulations - you just re-invented POV-Ray 3.7 (which is currently
in public beta phase) :P.
Except that 3.7 schedules square blocks instead of lines (to allow for
better efficiency of some caching mechanisms). And that things start
getting more complicated than you expect when it comes to some more
sophisticated features (like radiosity for instance).
Date: 6 Nov 2009 17:31:27
Message: <4af4a3bf@news.povray.org>
Also, if you don't want to install the beta, simply render half the
image (or animation) in one instance of POV-Ray; then open another
instance and execute the other half. (Assuming you have two cores.)
Mike
Date: 6 Nov 2009 19:01:19
Message: <4af4b8ce@news.povray.org>
  And assuming that the single instance is taking less than half of your
RAM...
