POV-Ray : Newsgroups : povray.bugreports : Spotted normal bug (Jerome M. Berger) Server Time
7 Mar 2026 12:29:22 EST (-0500)
  Spotted normal bug (Jerome M. Berger) (Message 1 to 2 of 2)
Subject: Spotted normal bug (Jerome M. Berger)
Date: 22 Nov 1999 20:40:23
Message: <3839f087@news.povray.org>
This file shows a bug in the spotted pattern. The bug manifests in
a visible square grid in the spotted pattern. It is also visible
in the bozo pattern.
The bumps normal does not show such a problem.
The bug does not show up when the patterns bozo, spotted and bumps
are used as pigments
Reference:
Message-ID: <38323B08.E75DD458@enst.fr>
Date: Tue, 16 Nov 1999 21:20:08 -0800
Newsgroups: povray.binaries.images
This bug has been verified by myself. System details follow:
CPU: AuthenticAMD AMD-K6tm w/ multimedia extensions, clock 193 MHz
RAM: 96 MB
OS : Microsoft Windows 98 4.10.1998
POV: Version 3.1g.watcom.win32 [Pentium II Optimised]
Peter Popov
pet### [at] usanet
union
  sphere { y+x, 1 }
  box { -1, 1 translate y-x }
  texture
    pigment { color rgb 1 }
    finish { phong 1 }
    normal { spotted 0.5 scale 1 }
light_source { <500,0,-100> color rgb 1 }
light_source { <0,500,-100> color rgb 1 }
camera
  location  <0.0 , 0.0 ,-2.25>
  up y
  right x
  look_at   <0.0 , 0.0 , 0.0>
  orthographic
Peter Popov
ICQ: 15002700
Subject: Re: Spotted normal bug (Jerome M. Berger)
Date: 23 Nov 1999 14:44:22
Message: <383aee96@news.povray.org>
Peter Popov <pet### [at] usanet> wrote...
Actually, the bozo/spotted pattern _does_ show this bug when used as a
pigment (it is just very subtle).  Below is a scene (modified from the one
provided by Peter), that puts the bozo bumps on a plane.  It will also
create contour lines in the pigment.  If you look closely, you can see how
the contour lines in the pigment match the grid-like pattern.
Therefore, this is most likely a bug in the bozo pattern itself, and is
probably related to what Xander posted a week or so ago.
-Nathan
// begin POV scene
plane{
  z,0
  texture
  #declare pig=yes;
  #if (pig)
    pigment { bozo color_map{
                     // s is delta for the contour lines
                     #declare s=.05
                     #declare a=0;
                     #while(a<=1)
                       [a rgb 1]
                       [a+s/4 rgb 1]
                       [a+s/4 rgb .5]
                       [a+s/4*2 rgb .5]
                       [a+s/4*2 rgb 1]
                       #declare a=a+s;
               scale 1}
    finish { specular 1 }
  #else
    normal { bozo 0.5*5
             slope_map{[0 <0,0>][1 <1,0>]}
             scale 1 }
// light_source { <0,500,-100> color rgb 1 }
camera
  location  <0.0 , 0.0 ,-2.25>*2
  up y
  right x
  orthographic
