POV-Ray : Newsgroups : povray.bugreports : Bug in noise function Server Time
18 Apr 2025 11:57:56 EDT (-0400)
  Bug in noise function (Message 1 to 5 of 5)
Subject: Bug in noise function
Date: 25 Aug 1999 06:57:12
Message: <37C3CBFD.78D4F5C5@peak.edu.ee>
There seems to be a bug in the various noise functions. It exhibits itself as
banding after a certain _negative_ distance, along any axis, from the origin.
This distance varies depending on the noise function: it is around 78.125 for
1/f noise (granite), 312.5 (78.125*4) for DNoise and Agate noise, and around
10000 for Perlin noise (bozo, bumps, spotted).
Furthermore, in 1/f and DNoise the bug seems to become more pronounced at
78.125*2 and 78.125*4
Versions: POVWin 3.1g (Watcom and VC compile), POV Superpatch (3.1e codebase).
The problem was also reported to exist on 3.01r1.watcom
System: Celeron, 128MB RAM, Win98
//BEGIN EXAMPLE SCENE
camera{
    orthographic
    location y*5
    up y*5*.75 right x*5
    look_at 0
//1/f noise (granite)
#declare Tex1=
pigment{
    granite
    color_map{[0 rgb 0][1 rgb 1]}
    translate 78.13*x //First signs of banding
    //translate 156.25*x //More pronounced
    //translate 312.5*x //Even more pronounced
    scale 5
//Perlin noise (Bozo & Bumps & Spotted)
#declare Tex2=
pigment{
    bozo
    translate 10000*x
    scale 1
//DNoise (turbulence)
#declare Tex3=
pigment{
    gradient x
    translate 312.5*x //Banding starts
    //translate 625*x //Becomes more pronounced
    scale 1
    turbulence 1
//Agate turbulence
#declare Tex4=
pigment{
    agate
    scale 5
plane{
    y,0
    pigment{Tex1}
    finish{ambient 1}
Subject: Re: Bug in noise function
Date: 25 Aug 1999 07:34:33
Message: <37C3D491.2130208B@pacbell.net>
It is also now reported to be evident in Pov v2.2.ibmibc copyright date 1993.
If it is a bug it has existed for quite some time now.
Ken Tyler
Date: 25 Aug 1999 08:34:28
Message: <37c3e2d4@news.povray.org>
I do not consider a precision problem a bug.
  You always choose a precision deliberately while bugs are unintentional.
Date: 25 Aug 1999 09:38:07
Message: <37c3f1bf@news.povray.org>
The problem is in texture.c, at the top:
/* Ridiculously large scaling values */
|#define MINX (-10000)
|#define MINY MINX
|#define MINZ MINX
The noise function only works in positive domains, so it first translates
your coordinate by -<MINX, MINY, MINZ> before computing noise.  As you can
see, this breaks at -10000.  Granite breaks at such a low offset because of
this:
|  VScale(tv1,EPoint,4.0);
|  for (i = 0; i < 6 ; freq *= 2.0, i++)
|    VScale(tv2,tv1,freq);
|    temp = 0.5 - Noise (tv2);
As you can see, your sample point will be scaled by up to a factor of 128.
Surprise, surprise: 10000/128=78.125.  Obviously, the larger your sample
point is, the more iterations of the 1/f code will be over 10000.  If you
determined this by experimentation, I'm impressed. :)
The fix is clearly to modify MINX and recompile.  Why it's set so low is
anybody's guess.
Date: 25 Aug 1999 10:15:47
Message: <37c3fa93@news.povray.org>
>anybody's guess.
Silly me, I should read all the groups before I respond to a post in
.bugreports. :)
A workaround, obviously, is to translate your texture to somewhere
positive.
