POV-Ray : Newsgroups : povray.bugreports : Intersection of rgbf-lathe with anything else -> Server Time
19 Apr 2025 06:53:58 EDT (-0400)
  Intersection of rgbf-lathe with anything else -> (Message 1 to 5 of 5)
Subject: Intersection of rgbf-lathe with anything else ->
Date: 24 Jun 1999 15:14:37
Message: <377283F5.B7476ABD@t-online.de>
Tanking an *Intersection* between
a *rgbf* *lathe* object
and an arbitrary object
results in only a few randomly distributed "reflective" pixels.
If you remove any of the highlighted (by *xxx*) conditions
above, the rendering is as expected.
replacing the intersection by "clipped_by" still leads to the
faulty? results.
***sth***
// Persistence Of Vision raytracer version 3.1 sample file.
// intersected rgbf lathe does not render properly (result is only a
sparse random pixel pattern)
// Win95 4.00.950B PII 300
// Povray 3.1e.msvc.win32 (PII optimized)
// File by Stefan Hahn
#declare eye = <-0.1,0.5,-0.1> ;
intersection {
   lathe {
      linear_spline 5
      <0.00,0>
      <0.025,0.01>
      <0.1,0.04>
      <0.2,0.0>
      <0.00,0>
      scale 0.1
      texture{pigment{color rgbf<1,1,1,0.9> }}
   cylinder {-y,y,0.05}
plane { y, 0
   pigment {  checker  color White color Red scale 0.03     }
   finish{ambient 0.2 diffuse 0.6}
   angle 30
   location eye
   up <0, 0.5, 0> right <0.6666, 0, 0>
   look_at <0,0,0>
light_source { <10, 10, -100> colour White }
Subject: Re: Intersection of rgbf-lathe with anything else ->
Date: 24 Jun 1999 15:42:25
Message: <37728a21@news.povray.org>
The problem, believe it or not, is coincident surfaces.   Moving
the plane just a tiny bit fixes it.  Why this only happens with
the intersection and not all the time is an interesting question,
but one for which I don't have the answer.
Subject: correction: problem is simpler (but still there)
Date: 24 Jun 1999 15:42:26
Message: <37728A6A.F445E55B@t-online.de>
I was wrong in describing the problem in the previous posting:
a rgbf-lathe has black measles on its own
in the following simpler file, the problem is already observable
but not so pronounced as in the example from my previous posting
// rgbf lathe does not render properly (result is only a sparse random
pixel pattern)
#declare eye = <-1,5,-1> ;
   lathe {
      linear_spline 5
      <0.00,0>
      <0.025,0.01>
      <0.1,0.04>
      <0.2,0.0>
      <0.00,0>
      pigment{color rgbf<1,1,1,0.5> }
//cosmetics only
plane { y, 0  pigment {  checker  color White color Red scale 0.03
}finish{ambient 0.2 diffuse 0.6}}
camera {angle 30 location <-1,5,-1>   up <0, 0.5, 0> right <0.6666, 0,
0> look_at <0,0,0> }
Subject: Re: correction: problem is simpler (but still there)
Date: 24 Jun 1999 15:43:55
Message: <37728a7b@news.povray.org>
Well, that answers my remaining question, then.  Move your cosmetic
plane and the problem should go away.
Date: 24 Jun 1999 15:48:10
Message: <37728939.B4D61AE@pacbell.net>
  Which is an elementary mistake many users make until they fully
understand the ins and outs of the program. I recommend discussing
these problems you are having in a different group before submitting
them as official bug reports. This will give you the benifit of finding
a possible solution or at least a confirmation by someone else prior
to reporting it here.
Ken Tyler
mailto://tylereng@pacbell.net
