POV-Ray : Newsgroups : povray.bugreports : cylinder renderbug? Server Time
30 Apr 2026 07:09:03 EDT (-0400)
  cylinder renderbug? (Message 1 to 3 of 3)
Subject: cylinder renderbug?
Date: 27 Apr 1999 10:53:37
Message: <3725C0A8.1D8B62C1@yahoo.com>
I had some strange rendering problemsw hen rendering a scene with an
object like this :
#declare MyObject1 = difference {
  cylinder { <0.0,-0.07, 0.0>, <0.0, 0.07, 0.0>, 85.935 }
  cylinder { <0.0,-1.00, 0.0>, <0.0, 1.00, 0.0>, 85.815 }
It looks like someone has cut some part of the 'sides' of the cylinder.
The endcaps are O.K., but it looks like two disks instead of a solid
ring.
This object is used within a pretty complex CSG, but the same problem
exists when rendering the object on its own.
When the ratio of radius to hight is > +/- 500, the problem disapears.
I had to solve this by using a higher cylinder and cutting the ring with
a plane :
#declare MyObject2 = difference {
  cylinder { <0.00,-0.07, 0.00>, <0.00, 5.00, 0.00>, 85.935 }
  cylinder { <0.00,-1.00, 0.00>, <0.00, 6.00, 0.00>, 85.815 }
  plane { y, -0.07 }
It should be seen with a little scene like this :
  location <-0.5, 0.5, 0.5>
  look_at <0.0, 0.0, 0.0>
light_source {
  <-5.0, 5.0, 5.0>
  color rgb <1.0, 1.0, 1.0>
object { MyObject1      //PROBLEMS !!!!!
// object { MyObject2     //PROLBLEM SOLVED !!!!!
  pigment { color rgb <1.0, 1.0, 0.5> }
  transform -85.875*y
Subject: Re: cylinder renderbug?
Date: 27 Apr 1999 10:57:37
Message: <3725C198.2E1B8704@yahoo.com>
What a mistake to make :
When the ratio of radius to hight is < (SMALLER !!!) +/- 500 the problem
disapears.
> object like this :
> ring.
> a plane :
>   plane { y, -0.07 }
> camera {
> light_source {
>   <-5.0, 5.0, 5.0>
>   transform -85.875*y
Date: 27 Apr 1999 22:56:08
Message: <37266A7C.CAA8CCF8@aol.com>
I didn't find anything wrong. Your example Object2 to correct the
supposed problem is wrong. At least it isn't the same as the Object1,
since it is leaving the upper y (wider section) instead of doing what
the first seems to be intended to do.
May just be your perspective of the shape and thinking of it
incorrectly. You simply have a very thin cylinder, very short in height
and large in diameter. To get the same for Object2 you would need a
plane {-y,-0.07} not what you have there. Hope this is right anyway, I
lost my first message reply.
> disapears.
> > object like this :
> > ring.
> > a plane :
> >   plane { y, -0.07 }
> > camera {
> > light_source {
> >   <-5.0, 5.0, 5.0>
> >   transform -85.875*y
