POV-Ray : Newsgroups : povray.bugreports : POV-Ray 3.1 for Windows editor bug Server Time
28 Nov 2026 05:17:17 EST (-0500)
  POV-Ray 3.1 for Windows editor bug (Message 1 to 10 of 10)
Subject: POV-Ray 3.1 for Windows editor bug
Date: 6 Feb 1999 21:45:57
Message: <36befe0a.4413797@news.povray.org>
Has anyone encountered the following problem: when a selection is cut
into the clipboard and has not been pasted yet, using ctrl-y to delete
a line clears the clipboard contents.Please tell me if it's replicable
so that I can send an official bug report.
Peter
Subject: Re: POV-Ray 3.1 for Windows editor bug
Date: 6 Feb 1999 22:01:06
Message: <36BD01B6.80E5438F@pacbell.net>
> Peter
This is a common characteristic of many word processing programs.
MS dos edit and many others use that key combination to cut a line
of text to the buffer which will indeed replace whatever was in there.
If you want to remove a line without putting it in the buffer place
the cursor at the beginning of the line, hold the shift key then
press the end button (or use the mouse to highlight the desired text),
release the keys and hit delete. If you hold the shift key while the
text is highlighted and hit the delete key it too will cut the text
into the buffer.
In conclusion this is not a bug it is a feature.
Ken Tyler
tyl### [at] pacbellnet
Date: 6 Feb 1999 22:24:39
Message: <36c8062b.6494477@news.povray.org>
>> Peter
>into the buffer.
Well, shift-del is the 'cut' key in Borland interfaces (that's where
I've seen it). ctrl-y is used there two, but it does not cut a line
but deletes it.  Also, the clipboard in Borland and Turbo Pascal and
C++ is not erased upon copying or cutting operation, but is like a
file in which things are pasted, so you can open it and copy from it
something you've used two hours ago. The point is, if you've seen this
ctrl-y problem in M$ Edit, it is because M$ can't even copy something
buglessly. That's my 34 lv.
Peter
Date: 6 Feb 1999 23:03:57
Message: <36BD1066.DB6DD20E@pacbell.net>
> Peter
Yep !
And some people like IBM compatible pc's while some like Mac's.
And some people prefer Windows while others swear by UNIX.
And some people prefer eating gourmet food while others eat dog biscuits.
So who we gotta kill before we get some consistancy around here anyway ?
Ken Tyler
Date: 7 Feb 1999 09:24:28
Message: <36BD239E.3089BF46@bahnhof.se>
> Peter
Another thing..
Since I'm also pretty used to the Borland(inprise) systems, I try
ctrl+delete to delete a line. Yes, I know, let go off ctrl, but when
working, it fits out of habit.
ctrl+delete takes parts off the next line too.
Mark a line in the middle, with a line under, press ctrl+del and whoppa,
part of the line beneath was killed.
//Spider
Date: 7 Feb 1999 13:07:23
Message: <36bfd5a6.892236@news.povray.org>
Everybody but yourself.  Or, if you prefer to kill yourself, everybody
but me.
Date: 7 Feb 1999 14:30:07
Message: <36BDE97C.3DE9B875@pacbell.net>
> Everybody but yourself.  Or, if you prefer to kill yourself, everybody but me.
I'll take that under advisement.
Date: 11 Feb 1999 00:44:27
Message: <01be5581$dca81e20$0c0b010a@angela>
Moral of the story, don't assume that the clipboard behaviour is what you
think.
After all, even dedicated MS users know that the clipboard doesn't work in
the "normal" fashion in Excel. If you copy some cells, then modify the
spreadsheet, then try to paste what you placed on the clipboard, it ain't
there anymore. This drove me nuts for weeks as I use the clipboard in this
way all the time in Lotus(which has it's own peculiarities). Copy a block,
make a bunch of changes, then if you don't like the result, paste it all
back again. It's a lot quicker than saving endless variants of your files.
Another example is the way MS have changed the drag-select operation. Try
to select the last two letters of one word, the space and the first two
letters of the next word with the mouse in IE 4 and you will see what I
mean. Do it in Notepad, it works there.
Bite the bullet, learn the new system, and learn to enjoy it because you'll
get to do it many more times in your future.
Enough of a rant from me!
Regards All
Gordon
<gbe### [at] birdcameroncomau>
Date: 11 Feb 1999 02:03:15
Message: <01be558c$c72a67a0$ef7581ce@angus>
I decided to mimic the MS Ctrl-Y behavior (Cut line) instead of the
Wordstar/Borland behavior (delete line) simply because I modeled CodeMax
after the DevStudio editor.
Barry Allyn - CodeMax author
WinMain Software
Date: 11 Feb 1999 02:18:46
Message: <01be558e$f15b1db0$ef7581ce@angus>
Ctrl+Delete in CodeMax is 'WordDeleteToEnd', not 'LineDelete'.  If you have
an extended selection and press Ctrl+Delete, CodeMax will extend the
selection to the end of the word (which may be on the next line) and delete
the entire selection.
If you still think you have encountered a bug, please let me know..
Thanks,
Barry Allyn
CodeMax author
Date: 11 Feb 1999 18:25:14
Message: <36C3659C.1B7CD8A3@bahnhof.se>
Thanx, I didn't think it was a bug, but I didn't know what it was
either... a generally good editor, but... how do I create my own
colour-shemes ???
//Spider
> Thanks,
> Barry Allyn
> CodeMax author
Date: 12 Feb 1999 00:07:01
Message: <36c3b405.2556824@news.povray.org>
On 11 Feb 1999 02:03:15 -0500, "Barry Allyn" <bar### [at] winmaincom>
>WinMain Software
Sir, I am glad I have the chance to personally congratulate you for
the wonderful editor you've made. The CodeMax editor is really neat
and has a lot of really great features, most of them I've seen in
other programs and liked a lot, but never saw all in the same place.
As it's clear now that the ctrl-y implementation it's a matter of
taste and not a bug, I humbly request that any replies to this message
are not posted to .bugreports, just here. It was my mistake, sorry I
crossposted .
(crouching in a corner asking for mercy),
Peter
Date: 12 Feb 1999 13:59:02
Message: <36c479f6.0@news.povray.org>
I'm not sure what you mean by color 'scheme'... ?  I assume you've seen the
'Color/Font' tab in the window properties and this is not what you are
looking for?
-Barry
Date: 12 Feb 1999 18:04:34
Message: <36C49E0E.98BD838C@bahnhof.se>
Not exactly, but say that I'd like to add some of my own most commonly
used objects, such as O_sun in a stale gray fashion in the scene, or
taht I'd like to open my <inser unsupported language here> files. How to
add/change this.
Example, how is a comment defined, can I re-define it, to use two key's,
"text comment" and "code alternative" byt the use of the codemax
definitions ?
I'm generally interested, since it is in my nature to come with theese
ideas when I get stuck in a scene. (I know, it happens a _lot_ :-)
//Spider
> looking for?
> -Barry
Date: 12 Feb 1999 22:05:22
Message: <01be56fd$e19a4110$b17581ce@angus>
The rules of the language, including comment styles, are hard-coded by the
application (i.e. POVRay).  So, to modify the comment delimiters, you are
requesting a change to POVRay, not CodeMax.
As for the custom color schemes, you are basically requesting that CodeMax
support more classes of tokens (which are customizable by the user).
Version 1.01 (the version in POVRay) does not support this concept.  I have
heard this request before, but it is low on my request list for the next
version (but it's on there!!)..
-Barry
Date: 12 Feb 1999 22:16:01
Message: <36C4ED27.3B7267B6@bahnhof.se>
Ok. Thanks for the information.
I can understand its low on the list. I'm just throwing ideas around.
As for other things of the list, there are lots of things that can
fit(reality.sys corrupted, please reset universe by running big:bang )
*smile*
It's nice to get replies, I thank you for your time.
//Spider
Date: 9 Jun 1999 00:27:20
Message: <375ded28@news.povray.org>
Ken wrote in message <36BD1066.DB6DD20E@pacbell.net>...
My solution is to run a Mac emulator on my PC.
Mark
Date: 9 Jun 1999 00:37:02
Message: <375DEBF2.D7C6A9C6@pacbell.net>
> Mark
  I had a Mac emultor set up for a short while but for me it was not worth
the resources it consumed on my system compared to the small amount of
Mac programs available that are even worth running. Almost everything I have
found in Mac software I have found 10 Windows programs that would do the
same thing.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 6 Feb 1999 22:15:54
Message: <36c705e5.6424327@news.povray.org>
>> Peter
>into the buffer.
Sorry about the cross-post, please follow-up to povray.windows since
it seems this is not a bug. Thank you.
Peter
