POV-Ray : Newsgroups : povray.bugreports : POVWin known bug #Win31-002 Server Time
27 Feb 2026 07:36:51 EST (-0500)
  POVWin known bug #Win31-002 (Message 1 to 1 of 1)
Subject: POVWin known bug #Win31-002
Date: 10 Feb 1999 08:00:57
Message: <36C182FA.7D59D8A1@compuserveNO-SPAM.com>
This known bug will be fixed in the next release of POV-Ray for Windows.
> Subject: Win95 (and maybe mac) bug: global_settings are persistent
> Date: Mon, 05 Oct 1998 00:29:28 GMT
> From: par### [at] mailfwicom (Ronald L. Parker)
> Newsgroups: povray.bugreports
> Description: I've found an annoying little bug in the Win95 GUI version
> of POVRay, and possibly in other GUI versions.  When you render a scene
> with max_trace_level set to something other than the default, it seems to
> remember that max_trace_level setting for the next render.  To test this,
> do the following:
> 1) create a scene that shows artifacts from a small max_trace_level.
> Render it.
> 2) add a line to the scene setting max_trace_level high enough to remove
> the artifacts.  Render it again.
> 3) remove the line setting max_trace_level and rerender.
> Notice that the result of (3) does not match the result of (1).  While
> this is basically only an annoyance, it may also apply to other global
> settings and should probably be fixed to avoid confusion.
