POV-Ray : Newsgroups : povray.bugreports : file names (Macintosh, Unix?,...) Server Time
21 Apr 2025 16:39:15 EDT (-0400)
  file names (Macintosh, Unix?,...) (Message 1 to 3 of 3)
Subject: file names (Macintosh, Unix?,...)
Date: 13 Jan 1999 13:03:36
Message: <1dlky41.1jior2r1en772uN@dialup22.leuven.skynet.be>
Looks like file names are causing problems on Macintosh, and perhaps
other platforms too (all platforms allowing spaces as first character in
file names).
We are aware that this is more an inconvenience than realy a bug but we
might have a solution.
For example if your input file is ' scene.pov' (notice the space in
front) POV-Ray is unable to find that file because while parsing the
option 'Input_File= scene.pov', the space is thrown away.
Why not not change the option parser in a way that options can be
enclosed like this:
Input_File=" scene.pov" and Version="3.1" ,......
Or perhaps allowing it only for library paths, input files, output
files, ..... all options relating to file names.
If an option is enclosed, the parser should take *all* characters,
including spaces.
Would it be hard to implement?
Yvo Smellenbergh
Subject: Re: file names (Macintosh, Unix?,...)
Date: 16 Jan 1999 19:33:37
Message: <36A13146.76B2787D@bahnhof.se>
with pov 3.1a, win95 there is anothr bug here(the same)
//Spider
> file names).
> enclosed like this:
> including spaces.
> Yvo Smellenbergh
Date: 13 Feb 1999 03:02:02
Message: <36C53223.8CFB5690@geocities.com>
That, i believe, might be because POV-Ray is documented as only supporting US-ASCII,
and
the o-umlaut is outside of that range.
So, how do you specify that character in a POV file so that you can include things
successfully? In theory, you can't use it.
> //Spider
