POV-Ray : Newsgroups : povray.bugreports : transmit does not work with image maps : Re: transmit does not work with image maps Server Time
29 Mar 2026 17:26:12 EDT (-0400)
Date: 23 Apr 2024 19:50:00
Message: <web.6628478ae419c9f791c33a706e066e29@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> According to POV-ray's  documentation, transmit all ...some value... *should*
> work correctly even on non-GIF images. I have successfully used it many
> times in the distant past. But currently, this  is the situation:
> In 'official' v3.7.0, it does work correctly with typical 24-bit .jpeg's and
> png's -- but has an odd problem with 32-bit alpha-channel images that already
> have a mask...
> But in the v3.8 beta releases, something changed--  transmit all  is
> completely *ignored*, when used with typical 24-bit images. However, it DOES
> work correctly if those images are re-saved as 32-bit .png...
I was looking at one of my old test-scene files, and realized that there is yet
another simple workaround for the 'transmit all' problem in the 3.8 betas...
which ALSO solves the odd problem in 3.7.0 with alpha-channel images: using an
averaged pigment_map with a plain 'transmit' value instead. The relative weights
of the average determine the translucency:
pigment{
    average
    pigment_map{
         [0.6 image_map{png "my image.png" once interpolate 2]
         // .jpeg, .png, .tiff; can an have an alpha-channel mask too.
         [0.4 transmit 1.0]
Of course, this would require re-editing old scene files to replace the original
'transmit all', which could be cumbersome. (BTW, tiff images may or may not need
the new 'premultiplied on/off' keyword for this,  if they have an actual
alpha-channel mask. In my tests, I had to turn it off to get better visual
results. I guess it depends on the app that creates such images.)
The simple construct above makes me wonder if 3.8's problem with 'transmit all'
(re: typical 24-bit images) may be the result of a minor source code difference
between it and plain 'transmit'...possibly a change that was introduced by
mistake.
