POV-Ray : Newsgroups : povray.bugreports : "mandel" as function in isosurface has unexpected results : Re: "mandel" as function in isosurface has unexpected results Server Time
16 Mar 2026 01:11:04 EDT (-0400)
Date: 20 Dec 2022 09:35:00
Message: <web.63a1c7d9c22c158f80a206e289db30a9@news.povray.org>
> Lars Rohwedder <rok### [at] gmxde> wrote:
> > So I had expected that a formula like 0.9 - mandel would give the
> > What went wrong here?
> Part of what's going wrong is that mandel is a POV-Ray pattern that has a built
> in color map.   And that wreaks hell with everything right from the beginning.
> I'd say try using:
> #declare Mandel = function { pigment {mandel 1000 exterior 1, 1 color_map {[0
> rgb 0] [1 rgb 1]}}}
Hi Bill and Lars
AFAIK, patterns can not have built in color maps, while pigments can.
So here I would rater suggest a pattern function instead of a pigment function:
#declare MandelbrotFn =
    function {
        pattern {
            mandel 1000
            exterior 1, 1
Pattern functions do not return colors as pigment functions do, but float values
between 0 and 1.
Patterns and pattern functions (and other functions returning floats) can be
used to select colors from color maps in pigments, e.g. like this:
    plane {
        +z, 0
            mandel 1000
            color_map {
                [ 0.0 color rgb <0, 0, 0> ]
                [ 0.2 color rgb <1, 0, 0> ]
                [ 0.4 color rgb <1, 1, 0> ]
                [ 1.0 color rgb <1, 1, 1> ]
                [ 1.0 color rgb <0, 0, 0> ]
- or like this:
    #declare MandelFn = function { pattern { mandel 1000 } };
    plane {
        +z, 0
            function { MandelFn(x, y, z) }
            color_map {
Tor Olav
http://subcube.com
https://github.com/t-o-k
