POV-Ray : Newsgroups : povray.bugreports : bump maps inverted in spherical warp : Re: bump maps inverted in spherical warp Server Time
18 Mar 2026 06:32:26 EDT (-0400)
Date: 4 Aug 2021 10:25:00
Message: <web.610aa29bfbcfb68e1e101ef1b9aee0ac@news.povray.org>
> Am 03.08.2021 um 22:19 schrieb pkoning:
> > I'm using a normal with a bump map, wrapped around a sphere using
> > warp{spherical}.  It looks normal in the northern hemisphere, but the bumps are
> > changed to depressions in the southern.
> This is a known issue that has been around for... well, ever since
> warped bump maps were first introduced, I guess.
> Sometimes the bumps even seem to turn "sideways".
And sometimes it doesn't happen.  Before today I haven't noticed it, though I
may have overlooked it.  In earlier tests I was using a plain texture instead of
the "cells" pattern, and then I don't remember seeing it.
Just  now I tried to reproduce it but I'm seeing a different baffling issue:
when I take out the "cells" pattern and replace it by a reference to a plain
texture, the parser complains that the "warp" modifier is not expected.  See
attached.
Possible Parse Error: Unmatched {
"/Users/pkoning/Documents/svn/tajemnica/bumpmap.pov"
 line 100
Parse Error: No matching }, warp found instead
Download 'bumpmap.pov.txt' (3 KB)
