POV-Ray : Newsgroups : povray.bugreports : alpha.10064268 macro problem : Re: alpha.10064268 macro problem Server Time
31 Mar 2026 12:29:10 EDT (-0400)
Date: 5 Apr 2021 18:30:00
Message: <web.606b8f1854e5aaba79819d986cde94f1@news.povray.org>
hi,
> I did a bit of hazy early-morning brainstorming.
(incorrigible  :-))
> You would be able to condense all of your nested #if statements if you were to
> write the largest one but then be able to skip certain nest levels.
the new code, published in p.t.scene-files a moment ago, is completely different
from previous.  for instance, only two walkers - void and bool.
> Can you use the parse thing to assemble a macro of the proper size on the fly?
don't see why it could not be used for that.
> Can conditionals be stored in an array?   Then you might be able to switch
> between #if and // nothing and #end and // nothing as needed.
never tried.  :-)
regards, jr.
