POV-Ray : Newsgroups : povray.bugreports : alpha.10064268 macro problem : Re: alpha.10064268 macro problem Server Time
15 Mar 2026 22:11:40 EDT (-0400)
Date: 4 Apr 2021 13:50:00
Message: <web.6069fc0554e5aaba1f9dae3025979125@news.povray.org>
Instead of a boolean, return an integer flag to be further processed.
(POV-Ray treats any non-zero value as "true")
Then you can initially process the result as a boolean like you do, but then
have a follow-up procedure that instantiates the sphere, maybe using #select.
Or maybe you can just do that with the simple "boolean" as well...
