POV-Ray : Newsgroups : povray.bugreports : alpha.10064268 freezes : Re: alpha.10064268 freezes Server Time
14 Mar 2026 23:23:24 EDT (-0400)
Date: 4 Dec 2019 12:15:01
Message: <web.5de7e87a48df159ffeeb22ff0@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 12/3/19 12:07 PM, jr wrote:
> >> Anyway, very likely more than a month before I'd have the time to look
> >> at this in any depth.
> > also no problem (for me).  out of interest, what advantages does your fork have
> > wrt media artefacts, media in general?
> :-) Simple question with a non-simple answer...
> I've never published a merged branch of all the branches I run as 'povr'
> - partly because what I run contains more branches / differences to
> master than those I've published to github. Also 'povr' is meant to be a
> temporal thing based on the current master branch into which continually
> re-based to master branches are merged.
> That said, my published solver branch addresses many artifacts media and
> otherwise - and extends the range over which containers work for media.
> This work though is limited to shapes using the common solvers.
sounds like a good starting point.  artefacts seem to appear when I use
interpolation, so interested in the difference that code will make.  what is the
build/install procedure?  (sorry to use up yr time, mostly familiar with the
usual '.tar's, not "pulling" (+ merging?))
http://news.povray.org/povray.binaries.images/thread/%3C5a842989%241%40news.povray.org%3E/
thank you for this link.  bookmarked.  much to take in.
regards, jr.
